This it stock, just pulled out of the box....
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Wow!! Just received my Mecool M8S Pro L, but will not play Netflix at all. Looking at DRM info, it has Widevine Level 1, which is great, HOWEVER, the HDCP level is UNPROTECTED. Does all your boxes have the HDCP level supported???????????
This it stock, just pulled out of the box....MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostWow!! Just received my Mecool M8S Pro L, but will not play Netflix at all. Looking at DRM info, it has Widevine Level 1, which is great, HOWEVER, the HDCP level is UNPROTECTED. Does all your boxes have the HDCP level supported???????????
Guest
Originally posted by sweetnonso View Post
Mine plays Netflix on 1080p with this custom rom, and also have HDCP level 1.x supported. When my box arrived through the post, i didn't bother checking out the stock rom, i just installed this custom rom straight away.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Magendanz View PostYou should see this:MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
scooter2014 commented
11-02-2017, 14:49
That way it can take over your vacume because you know all your devices are talking about you already
I think my new robot vacuum should start eating some of my boxes..........MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Gearbest website........... First order from them, always have used Geekbuying........ guess I will take a look at that site.....
EDIT: It says Netflix in HD........
Hi Magendanz,
Im gonna buy this box TV soon. I was to buy a xiaomi mi box before.
Is there any other bugs in the tvstock rom ? Is it as smooth and fluid as mis box ?
I want this box because of s912 et 3gb RAM.
Thank.
There are two bugs that are related to power management in the underlying OEM firmware that I'm tracking. One causes wake from sleep to restart, and the other is a rare system hang. I'm hoping they'll be fixed in the next release. Other than that (and the longstanding Google Cast issue), it's very solid and smooth. As I mentioned before, it's now my main box (and I have lots to choose from at this point).
There are currently 1964 users online. 3 members and 1961 guests.
