[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
What are the chances of something like this working on this device with this ROM? I need 5.1 for my 6-ch (3x3.5mm) PC speakers, no DD+ or any HD audio. Comments say it works out-of-the-box on windows/linux/mac. But Android TV, probably not eh?
#227.1Guest commented30 November 2017, 01:04Editing a commentI don't think that my custom ROM would be any different than the stock OEM ROM, so you're probably better asking the larger audience here: http://freaktab.com/forum/tv-player-...uetooth-4-1-hs
Hello everyone, I installed the zip code v0928, known that there is no terminal app to be activated in the developer options and the drawer, I'm wrong? Thanks for the good work will there be multitasking in the future on the Android TV for the pro L? GuestLast edited by Yugo79; 01 December 2017, 12:54.
Originally posted by Yugo79 View PostThanks tonight I'll look at it, on beelink it's simply called active terminal app. How come they do not have the same development? Atv on beelink I find it with more features. Will there be multitasking on the pro L? Thanks so much
Hello, is this firmware compatible with the
MECOOL M8S PRO DDR4 3GB eMMC 32GB Amlogic S912
(https://www.geekbuying.com/item/MECO...ox-389323.html)
or did someone try it with this box?
The difference between the L and the non L version I can see is the DDR4 RAM (instead of DDR3, the S912 asic seems to be the same)
[QUOTE = nitro82; n690450]
Puoi richiamare il multitasking premendo due volte il tasto home. [/ QUOTE]
On the pro L it does not go, on the beelink instead
vahttps://www.amazon.it/dp/B01KJRK7AQ/..._6SxiAbFZS8JT9Last edited by Yugo79; 01 December 2017, 18:08.
Sul pro L non va, sul beelink invece yes. https://www.amazon.it/dp/B01KJRK7AQ/..._6SxiAbFZS8JT9
P.S. Are you Italian too?
heres a little more info on that gamepad that im trying to get working
got this from LSUSB -V ON linux
Bus 003 Device 003: ID 0079:0011 DragonRise Inc. Gamepad
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 8
idVendor 0x0079 DragonRise Inc.
idProduct 0x0011 Gamepad
bcdDevice 1.06
iManufacturer 0
iProduct 2
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0 No Subclass
bInterfaceProtocol 0 None
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.10
bCountryCode 33 US
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 101
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 10
Guest
Changelog (20171202):- Updated to latest M8S Pro L OEM firmware (20171127.165619.V0928)
- Added local update and backup option from Settings->About->System update based on Amlogic stock OTAUpgrade app.
- Latest build from Open GApps (20171202)
- Wake from sleep will usually result in a restart. This seems to be a bug in the underlying OEM firmware.
- Google Cast service broadcasts and is discoverable from mobile devices, but usually quits unexpectedly when connected.
- TVStock Variant: BURN PACKAGE (997MB IMG file), OTA UPDATE (528MB ZIP file)
Originally posted by Magendanz View PostChangelog (20171202):- Updated to latest M8S Pro L OEM firmware (20171127.165619.V0928)
About bugs really is a problem of the manufacturer's software, I simply avoid the same as follows:
Temporary Solution:- On option Powerkey Definition change "Sleep Now" to "Shutdown". This will force you to get accustomed to "new function" of the power key. This way you will only use the key to turn the unit off.
- To use the Chromecast feature use the AirScreen app, it is not as efficient as a Chromecast, but you can use screen mirroring as well as DLNA with a compatible app on your device.
There are currently 2934 users online. 1 members and 2933 guests.
