[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
I also think that my problem is overheating. TV boxing hangs every 20-40 minutes when I watch the video. It is necessary to disconnect from the socket and wait for it to cool before the image appears again. I want to use radiators from old motherboards.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by mr.Alexander View PostI also think that my problem is overheating. TV boxing hangs every 20-40 minutes when I watch the video. It is necessary to disconnect from the socket and wait for it to cool before the image appears again. I want to use radiators from old motherboards.Originally posted by P.X View PostGot Heat Problems ?
1. Use a better glue. The std. glue can be applied too thickly and is not the best thermally anyway (my guess)
Arctic Silver Epoxy is the best - Close second is the Aluminium version - Note this is PERMANENT Glue.
I used small bead in the centre and this is spread thinly by pressure. I used a 2.75Kg mass.
+ 2. Use a better Heatsink - a 22x22x10mm fits easily and costs buttons ont Bay
Or + 3. Taller HS adds a bit of an extra Air-Gap
But - as stated a change to a decent thermal glue is simple and provides great results.
A bigger HS will always help of course, assuming there is room ...
10mm High .....................15mm High.....................15mm= +air-gap
Good glue ~20C better than thick, poor glue !
Bigger/Taller HS ~3-5C better again
The Pro L has a 28x28x6mm HS and a 10mm upgrade fits easily.
Originally posted by korgix300 View Post
Megadenz how do I install this ATV ROM (zip file) of yours on stock unit?
thank you
I tried that then it reboots and never gets past the Mecool logo just hangs there. I am updating via usb stick. I am uaing your fixes 619 zip.
I rebooted into recovery and did the install all good now. One issue I keep having is freezes when running this ROM lol, anything that can be done?
How about power key on remote definition seems not to work ... I will try to work on that I might know how.Also do you know where the bootanimation is located for both nexus and android animations?
Yep, you got a bootloop. Welcome to my world! :-)
The problem with the M8S Pro L (and now the M8S Pro+) is that they don't have reset switches, so in this scenario you can't easily hold it down during power-up to enter recovery mode. Also, we don't have an Amlogic burn package (.img file), and so there's no recovery in Mask ROM mode if you screw up the bootloader.
What you're going to have to do is open up the case and short the pins where the reset switch used to be mounted. If you plan on doing this regularly, you might also consider soldering on a switch.
Originally posted by Mples View Post
I put the rom that Magedanz made me
now I'm with stock
p.s. I want to point out that I changed the model name and a few other parameters in build.propprior to getting boot loop
There are currently 891 users online. 0 members and 891 guests.
