[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Hope someone can help.
Installed rom from page 1.
All ok and then put a few apps on it.
For some reason a restricted profile has arrived on the box.
Asking for a pin.
Any idea what the pin could be ?
I did not set a restricted profile up ( i installed adclear not sure if this has done it ? ).
If all else fails how can i boot into recovery and install the rom again ?
Thanks for any help.
Originally posted by zx-9r View PostHi,
I've bought this box and will receive it this week.
I'm going to install this ROM, should I somehow back up original firmware? Or I can just choose to update to this ROM?
Thanks!
Originally posted by kingsemperor
It is best to have the original firmware backed up (in case something happens), on the other hand you could flash it direct, mine worked without problems (at your own risk).
What's the easiest way to backup the original firmware?
Thanks!
#130.1Guest commented07 November 2017, 00:49Editing a commentWell, since it's rooted you can type "su" from Terminal and just use the "dd if=/dev/block/system of=system.img" command to dump each partition (system, boot, bootloader, etc.) to a raw image file. However, if your firmware version is just "20170918.111557.V0619" then we've already got that archived here: https://mega.nz/#F!GJMCDCqa!ZIPErel0XHifEyQMIOAelw
Hello people! I recently bought a tv-box m8s pro L. I do not like the Play Marketinstalled in the firmware M8S_PRO_L-ota-20170918.111557.V0619.zip. Perhaps it can be replaced by the classic Play Market, for example, as on a smartphone or tablet. In the current version of the Play Market there are not many applications that I need. Tell me, how to get the classic Play Market?
Originally posted by mr.Alexander View PostHello people! I recently bought a tv-box m8s pro L. I do not like the Play Marketinstalled in the firmware M8S_PRO_L-ota-20170918.111557.V0619.zip. Perhaps it can be replaced by the classic Play Market, for example, as on a smartphone or tablet. In the current version of the Play Market there are not many applications that I need. Tell me, how to get the classic Play Market?
it is the same version as you get on Sony tv' and shield tv
There are currently 2502 users online. 1 members and 2501 guests.
