[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
You need to install it in TWRP recovery. From Terminal app (enabled in Developer Options), type "reboot recovery", hit Install, pick .zip file, and swipe to install. If Developer Options isn't enabled, you need to click Build number in Settings->About 7 times.
Note: I'm working on my own Update app that will also include a button to reboot to recovery.
I type it reboot recovery in terminal and after reboot nexus logo and black screen nothing happen....you can put an app in your rom to be like original one to be possible to chose a zip inside a rom ,and be automatically installed pls
I tried also with different apps to reboot in recovery but nothing just reboot in system ,so I believe twrp is not inside your rom.....
From the latest OEM firmware, I just ran the Update app and selected "update_M8S_PRO_L-V0928_TVStock-20171115.zip" with a Data Wipe. It rebooted to the stock recovery for the install, erased the user data partition, and returned to the custom Android TV system. After running through the setup wizard, I opened Terminal and typed "reboot recovery"...and it rebooted to TWRP 3.1.1-0. So, I'm pretty confident that TWRP is inside my update.
Easy just download his latest of a put on usb or as card. Start box. Go to update program select local update. Click update. Box will reboot install the update reboot. Your done. Could not be any simplerMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
It same program in apks as in the other builds that has not changed. Updated is in that build as well. The update to the other firmware if you want to go that route is usb burning tool and male to male usbMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Guest
IM currently running latest ATV rom from you, If I want to roll back to original mecool rom. Should I just flash it in twrp?
Yes, but use one of the "-fixed" versions that I've created here to work around their update script bug: http://freaktab.org/28~f
There are currently 3003 users online. 1 members and 3002 guests.
