[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Guest
Originally posted by Mples View Post
thousand thank you guys worked
Always be well
thousand thanks in
Magendanz
Hello, Mples, can you explain exactly what you did to get your box working?? Also, did you get Mangendanz's ROM installed on your box?? Thanks
now I'm with stock
Originally posted by sweetnonso View PostCan Magendanz or anyone please weigh in here, my box keeps going off after being idle for a while, say overnight, and i have to unplug and plug it back in to switch it on. Both my mini m8s ii and alfawise S92 stays on even when i leave them idle for two days straight, I have checked and rechecked the backdrop settings etc, don't know where am getting it wrong, Any and all help will be appreciated.
Good evening. I received a box Mecool M8S Pro L, but it is constantly blocking. Unlocks only when unplugged. I have already installed this version of the update, but the problem remains. Any suggestion? Have you thought about getting the beelink gt1 ultimate firmware, will it be compatible? Anticipated thanks.
Originally posted by nitro82 View PostGuest crashes and blocks (after being idle for a while) happen to me, sweetnonso and Mples too. For example after every night I have to unplug and plug it back to switch on the box.
I ve just swapped the HDMI cable that came with the box with an HDMI cable I have lying around in the house. Am just trying any and all things, maybe I will get lucky, or Guest will figure it out at some point.
Another problem I have is that, even if I choose "sleep now' in "Powerkey definition", when I press the button on remote it turns off and not goes on sleep. Practically it gives me the same behaviour of "shutdown" option. Do you have this too?
Originally posted by jomagaar View PostHello, can anyone help by typing exactly the commands to access TWRP through the terminal app?
Thank you
There are currently 2417 users online. 0 members and 2417 guests.
