[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
    Originally posted by Mples View Post
    You'll need to short the reset pads on the PCB and hold it for about 20 seconds while connecting the power. Alternatively,Â* ??????
    what is it that I need to short-circuit
    €‹and how it opens the box
    To open the box - Remove the 4x rubber feet.
    4x small cross head (JIS) screws - Careful, a standard Philips screwdriver will cam-out and damage the screws if not pushed in firmly while unscrewing !
    Lid comes off easily.
    Front right of PCB is a space for the Reset Switch (not fitted) marked 2SW4
    Short Front Left - to - Front Right (either side of the + symbol in Pro+ photo)
    Photo of Pro+ (very similar)
      Click image for larger version  Name:	IMG_20171020_071824.jpg Views:	1 Size:	116.5 KB ID:	679191
        this is mine box
        this must be done ??Click image for larger version  Name:	image_27836.jpg Views:	1 Size:	106.5 KB ID:	679193
          this is mine box
          Yes.
          Short, add power and keep shorted for up to about 20 seconds I believe.
          Is your heatsink OK? Looks out of place ??
            I managed to get back to the menu but I can not install it
            what exactly is the procedure ?
              Please
              what is the zip that I need to put on to get the box back ??
                        Have to get an expert to help with this .... Magendanz is on Pacific Time I think, so may be a slight wait ....
                        • Guest's Avatar
                          Guest commented
                          Editing a comment
                          This is a bug with the OEM's update script, which is checking the build.prop on the recovery (TWRP) and not the system partition. Since we use a generic TWRP build for q20x reference boards, it won't match the model device name that it expects.
                        #42
                        Is there anything Mples can do except wait and hope VS release a corrected version ?
                        He can load your ROM I guess ?
                        • Guest's Avatar
                          Guest commented
                          Editing a comment
                          Hold on just a few minutes more. I'm uploading the fix now...
                        #43
                        Where is the Superhero emoticon ???
                        You are too amazing
                        I am guessing this will help all who need to revert to OEM for some reason.
                          Okay, try this: M8S_PRO_L-ota-20170918.111557.V0619-fixed.zip
                          I've also made it so that you can downgrade using this OTA updater, which the OEM script wouldn't let you do.
                            thank you downloading it now
