One thing that works for me, when I use that remote for another device and then go back to this device I have to remove the batteries and re-insert them. That works for me..... give it a try. Also, after I re-insert the batteries, I reboot my box, hold my remote a few inches from the box while depressing both the "OK" and "-" buttons until the box pairs, can take a few minutes.
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by Appys View Post
One thing that works for me, when I use that remote for another device and then go back to this device I have to remove the batteries and re-insert them. That works for me..... give it a try. Also, after I re-insert the batteries, I reboot my box, hold my remote a few inches from the box while depressing both the "OK" and "-" buttons until the box pairs, can take a few minutes.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There is no stock firmware for the "LB", as I am aware of, but there is a TWRP backup for that firmware floating around here someplace. You are the first person that has issues with that remote on this site, that I am aware of..........
One thing that works for me, when I use that remote for another device and then go back to this device I have to remove the batteries and re-insert them. That works for me..... give it a try. Also, after I re-insert the batteries, I reboot my box, hold my remote a few inches from the box while depressing both the "OK" and "-" buttons until the box pairs, can take a few minutes.Last edited by Appys; 10 June 2018, 02:52.
Yep did that, to be clear I see the remote in my phones bluetooth scans but I don't see the box in the scan ever.. I tried your method but not sure if the WiFi /Bluetooth module isn't transmitting the remote would pair,held it hard for 2 minutes straight nothing, "Bluetooth is initializing".. The few hours the box worked on shipped firmware before this mecool ota update, WiFi and bluetooth sliders showed disabled no matter what I tried ..
Originally posted by supermal View Posthttps://mega.nz/#!AZIjjT7D!k-Z6eSZFa...Gij_9qtVSna1Uo here is the link for LB VARIANT ONLY!!!
This is where all my problem come from, after resetting, the start up color symbol would just stay there, so after many hour of trying to load the nexus Rom from the recovery (hitting the menu button on start up) i resorted by loading it using the USB burning tool and shorting it, by using the paper clip method, but with no WiFi and no voice control but at least i had it working, but would like to go back to the original imagine.
Originally posted by weldermike View Post
Hi, how would i load this on to my Mecool m8s pro LB ?? and is there a way to go back to my original imagine by using the USB burning tool method which i can do confidently, I got my box on Saturday and after a couple of hour, had trouble with my play store, so after deleting data and the cache thought i could do a factory reset.
This is where all my problem come from, after resetting, the start up color symbol would just stay there, so after many hour of trying to load the nexus Rom from the recovery (hitting the menu button on start up) i resorted by loading it using the USB burning tool and shorting it, by using the paper clip method, but with no WiFi and no voice control but at least i had it working, but would like to go back to the original imagine.Last edited by Appys; 12 June 2018, 03:17.
Im a noob so kindly excuse, but what do you mean by usb burning tool and shorting, I supposed there is a pin to be inserted in the backside hole and USB burning tool auto connects and we wrote the image and that's all.. What's this shorting thing .. I too am almost in the same boat as I want to load supermal image to go back on my new lb box
Edit: follow this video, but instead of having an accessable reset button, you will need to open your box, but the method is the same.
Here is a photo of where to short the pins...... post #183
They removed the accessible reset switch, so you have to open the box and short the two spots where the reset button is supposed to be. There is a picture floating around here someplace (I will look for it). You will need a male to male USB cable, and while shorting the "pin holes", plug in the USB cable into the OTG port on your box. Your computer will make a noise when it connects to the box.
http://freaktab.com/forum/tv-player-...-tv-7-1/page13
Thanks Sir, you come to the rescue again..I will do it now since my posts to the vendor go un understood, seems they are just resellers with no freakin clue..want to try going back to March OEM version of this box before considering a return
There are other methods to swap firmwares, but this is the best method.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Im a noob so kindly excuse, but what do you mean by usb burning tool and shorting, I supposed there is a pin to be inserted in the backside hole and USB burning tool auto connects and we wrote the image directly on the device flash via pc connection and usb to usb male,and that's all per https://www.youtube.com/watch?v=80U_eXgvitY . Do I need to short the pins necessarily and open the box for any new image flashing? I too am almost in the same boat as I want to load supermal image to go back on my new lb box
will update when I try it later.
thanks for everyone help and hopefully people can read this and learn from it lol.
Originally posted by weldermike View PostHi, just unzipped the file and tried to import the recovery image file on USB burning tool but it says parse burning iamge fail.
The file size was 86.8 MB is this the correct one ?
Thanks and sorry for being a pain.
freaktab.org/a28c3f52268572bb you can also try this firmware.this is the stock firmware that came installed on my box.if you use this one and it loads up ok,if you go onto the update app and check for updates it should say there is a update available.it is just a small update which makes box microsoft playready.whatever that may be.good luck!apologies as it looks like the first link i gave may be just the small update.therefore use link in this post.Last edited by supermal; 12 June 2018, 09:13.
There are currently 1459 users online. 1 members and 1458 guests.
