[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Hi guys! I´m completely new to the world of Amlogic Boxes, and as I´m going to buy the Meecool M8S Pro L i wanted to know if Amazon Video and Netflix do work on this ROM. If so, does it run 4K und can it switch between SDR and HDR automatically? Last question: Is there a thing such as framerate switching for content below 60hz (23,97, 25, 30 etc)?
Originally posted by masked__rider View PostHi guys! I´m completely new to the world of Amlogic Boxes, and as I´m going to buy the Meecool M8S Pro L i wanted to know if Amazon Video and Netflix do work on this ROM. If so, does it run 4K und can it switch between SDR and HDR automatically? Last question: Is there a thing such as framerate switching for content below 60hz (23,97, 25, 30 etc)?
Originally posted by supermal View Post
if amazon video works at all it will be sd only.netflix works up to 4k depending on your subscription.i think videostrong dropped support for framerate switching for some reason.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
now where getting somewhere!nothing wrong with your box!!!i disconnected my avr from my mecool box and connected direct to tv.now my settings in kodi are the same as yours.so your avr is not getting correct hdmi handshake with your mecool box.there is two hdmi cables that have to be the right spec for one thing.second settings on your avr and mecool box need to be correct.third settings in kodi need to be correct.trial and error my friend and you will succeed.look at your avr manual to see if that helps.when i first got my avr i could not get dolby atmos to show on my read out.thought avr was not working.turns out you need to have a pair of extra speakers connected for the avr to see and output correct audio stream.all new to me at the time but a simple set up error and it wont work.good luck anyway im sure you will get there.
As for the things you mentioned I've been able to rule out a few. The only new component in my setup is the mecool box. I've had my avr setup outputting HD Audio via a couple of different computers connected to the avr over the years with HDMI 1.4 cables. Ruled out the cables being the culprit by swapping them out for HDMI 2.0 cables. I'll keep digging...
Originally posted by mynameismartha View Post
Thanks for persevering supermal, I dp suspect its a hardware\firmware combination issue somewhere in the pipeline but the exact place is proving illusive.
As for the things you mentioned I've been able to rule out a few. The only new component in my setup is the mecool box. I've had my avr setup outputting HD Audio via a couple of different computers connected to the avr over the years with HDMI 1.4 cables. Ruled out the cables being the culprit by swapping them out for HDMI 2.0 cables. I'll keep digging...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Netflix is only HD (1080P), YouTube is 4k.Last edited by DreamSeason; 09 May 2018, 10:06.
Guest
What is your speaker set up on your avr?if it is not configured for 7.1 it will default to 5.1 output.
Guest
Just for sh*ts and grins, connect your box directly to your TV and see what Kodi shows. The Audio settings should be the same, HD audio not available. Then, connect it to your AVR again on a different port (your AVR should have several HDMI ports), and see it Kodi finally shows the HD audio selection in you audio settings. For whatever reason, your box is not seeing a device that can decode the HD audio streams.
Attempted that numerous times and swapped in power cycles and other hdmi devices into the mix just to make sure it wasn't a memory flush issue. I'll look in EDID info when I get time after work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1490 users online. 2 members and 1488 guests.
