[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by Magendanz View PostOkay, try this: M8S_PRO_L-ota-20170918.111557.V0619-fixed.zip
I've also made it so that you can downgrade using this OTA updater, which the OEM script wouldn't let you do.
First of all, thnx for all the good work. I am using this wonderfull rom for some time now.
However, since yesterday suddenly my Netflix app stopped working. Normally this solves itself after a reboot but yesterday after the reboot the app won't open at all (just a black screen). I tried to launch the DRM app and the same happens (black screen, after a couple of minutes a pop-up "app does not respond").
Any clues? It looks like something suddenly has gone wrong with the DRM or something?
Originally posted by itnetwork View PostFirst of all, thnx for all the good work. I am using this wonderfull rom for some time now.
Originally posted by zenix View Post
DRM has nothing to do if netflix working or not . Try to clear cach / memory or try sideloading another netflix app from apkmirror .
Decided to try another ROM but the official OTA gives the same result. What is going on?
I found this thread and it looks similar to mine. No solution is provided until now.
flashed nexus rom to my m8s pro l, upgrade went easy, but on first boot i couldnt pass setup part because wifi not working, same thing happens now with all other available roms for this device. is there way to fix this, or flash back to original. i flashed with twrp shorting the switch.. thx
Hi everyone
I am just buying new MECOOL M8S PRO L 3GB/32GB android tv box for watching amazone prime videos
But prime video app is not avilabel in appstore and i tried sideloaded app for it but it is not working so i need help for how to install prime video app on my tvbox.
So i want to know this prime video app is working on this rom [ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1) ?
I dont know how to install this ROM
So what can i do for watching prime videos on my MECOOL M8S PRO L 3GB/32GB android tv box ?
And one more problem with this tv box it's every time freezing
So i request to all friends please help me what to do ?
Also, the freezing issue could be caused by one of your apps that you are running,
Give this a try and see if Amazon Prime works with this app installed from the Aptoid play store. I don't subscribe to Amazon Prime, so I could not verify if it, indeed played the video.
https://www.youtube.com/watch?v=f9v0OseWQ0M&t=72s
I install this app from aptoid on my original mecool rom
But this version of app for sony tv
When I register my prime video account and try to wach video i found this error which attached in photo
ThanksYou may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Thanks for your guidance
ThanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Their is any solution for this ?
Magendanz's this rom [ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1) is solution for this ?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1845 users online. 0 members and 1845 guests.
