In my box does not work generic USB controls ...
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
So I just installed 20180310 and I use a usb air mouse model mx3 and I am having a problem with the ok button. It doesn't work as intended on this ROM. Worked fine on stock.
Problem I notice is that when I'm using onscreen keyboard to type and I prees ok on the letter I want to select it just didn't respond.
But navigation of menus and selecting things works as intended
I've attached video showing issue
https://media.giphy.com/media/fdYdD6...v8Bf/giphy.gif
In video I try to show that pressing ok to select doesnt work, but then with airmouse ok button works fine.Attached FilesLast edited by bayard0; 29 March 2018, 13:14.
Hi guys.
I have installed the latest Android TV OTA ROM over the stock ROM (I reveiced the box yesterday). I did use wipe data.
My problem is that no matter what resolution I have tried, Netflix and Kodi (with local mkv files) is pretty much unwatchable. The motion is terrible, with continues hickups.
P.S. The problem was there prior to the Android TV ROM but I'm not sure it was that intense.
Any ideas?
Well despite everything I tried, I couldn't install it.
First I didn't have the "Local Terminal" in the developer menu so had to install "Terminal Emulator" to be able to reboot in recovery mode.
Then I just couldn't get it to be detected by windows / USB Burning Tool. Finally I tried with an SD and BootCardMaker but nope... it did absolutely nothing.
If anyone has an idea I'd really love to hear it !
Kernel Version: 3.14.29 Fri Nov 17 16:42:45
Build Number: M8S PRO L-userdebug 7.1.1 NHG47L20171117.164057.V0928
Originally posted by neko.baka View PostWell despite everything I tried, I couldn't install it.
If it does work, make sure you have a usb mouse or something to navigate TWRP if you ever go back in to it as the remote doesn't work. I'll check back to see if you have any success.
Hi Magendanz, thank you very much for the cfw! I'm using your ATV versions on my M8S Pro+ and Pro L and everything works just fine!
I just have one question. Is it possible to save and restore the L1 keys? I don't want to loose them and would like to have a copy in case I mess something up and delete them.
I've read that they are in the trustzone store and it's not that easy to extract them, but I don't know if its true.
Thank you!
Why i have got black screen when playing x265 - HEVC on some files?
There is an example i tried (right top corner is download button)
https://drive.google.com/file/d/1eKb...ew?usp=sharing
I tried kodi and mx player.
Another problem i can't install kodi 64bit and vlc player because it say it is not compatible with my tv. How to workaround this?Last edited by tosiek; 30 March 2018, 16:18.
Originally posted by tosiek View PostWhy i have got black screen when playing x265 - HEVC on some files?
Originally posted by coubi64 View PostI've successfully installed this latest rom and everything works fine except voice.
I'v got this model:MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1681 users online. 0 members and 1681 guests.
