[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by zenix View Post
Sorry but i believe it s a silly question. What makes you think that maby you cant install it?
I am considering buying this box but i NEED to know a few things I can not find anywhere else...
I need the box to be able to use a USB HD (OTG) I think it is called? I also need to to have SAMBA SERVER support.
In the past, some boxes would not let the SAMBA apps run because I could not get root.
If I buy this box AND use this ROM, will I have root and still have bluetooth and USB HD capabilities? And can anybody confirm if they are able to get SAMBA to work on it?
Sorry for all the questions, but you would REALLY help me out. I am on my FIFTH box trying to get one that will do all 3 things I need!
Originally posted by FenriX89 View PostI've the latest board with KM63350816
Is there something we can edit in the update to make it work with this WiFi chip?
You can see which model you have by looking at the bottom of the box.
Hopefully the developers will update their custom ROMs with the newer chipset.
Originally posted by mike_la View Post
DO NOT install any of the custom ROMs if you do not have LQ model (Initial release) The newer LB model has new Wifi and Bluetooth chip, you will lose all network. AFAIK, all of the current ROMs available are based on the older Model.
Yeah I noticed, I already made a big mess, going through several rom changes and than back to the old one through a backup, I was asking if we can unpack the rom and add the right drivers somehow, I never did it but I'm quite sure there's a way
Hello Guest , Im a fan and user of your ATV rom for the Mecool m8s Pro L, while reading another thread I found the OTA update_NHG47L_20180417.150752.V0213
this zip with the OTA have the files and libraries to add Microsoft Playready DRM, its on the folders
/system/etc/drm/playready
/lib/libplayready.so
/vendor/lib/drm/libdrmclientplayreadyplugin.so
/vendor/lib/mediadrm/libplayreadymediadrmplugin.so
The post where this OTA came from:
Maybe this can be added to the next update
Thanks in advance
Guest
Guest
Has anyone been able to get HDMI RAW audio passthrough working with DTS-HD and TrueHD with stock or any custom rom?
Guest
Okay, I've run into a problem using the 20180417.150752.V0213 OEM kernel. Going through my normal development process, I was able to build all variants with the new OEM firmware. However, they switched from the QCA9377 to the BCM4335 wireless chipset, so WiFi and Bluetooth don't work on any of my M8S PRO L boxes.
My strategy was to just pull over the latest QCA9377 kernel and init.amlogic.wifi.rc, repacking the build image using the usual procedure. However, this results in a hang after the logo screen. No matter what I did, the old kernel would always fail to load, and the new kernel is missing the kernel compatibility layer that the QCA9377 uses through compat.ko.
Does anyone have a newer OEM firmware release for the M8S PRO L SKUs that used the old QCA9377 wireless chipset? The latest I can find is 20180205.111652.V0928.
Originally posted by mynameismartha View PostHas anyone been able to get HDMI RAW audio passthrough working with DTS-HD and TrueHD with stock or any custom rom?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 3906 users online. 1 members and 3905 guests.
