[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by supermal View Post
LB has different wi-fi/Bluetooth module to previous versions.you loaded a custom rom that is not compatible.you need to go back to stock.
Originally posted by Norbert_Susman View Post
Can I just flash a compatible rom over it or do I need to go stock and then flash the compatible rom? Btw where can I find a compatible rom? and thank you for the help!
Originally posted by mynameismartha View Post
At this stage I'm fairly certain it's a firmware/android/avr compatibility issue. Not sure if you saw my previous post above but it looks to be a compatibility problem with the new android audiotrack api introduced for surround sound in Marshmellow and Onkyo. Ever so slowly inching towards solutions...
Guest
try this version of spmc to see if it gives you the hd audio options in settings.spmc 16.7 -04.
Yeah I see the HD audio options with expert settings SPMC. Unfortunately passthrough of HD audio still doesn't work. I have to disable 'amcodec' acceleration just to prevent it from crashing when playing any video.
First of all, i must thank the author for the ROM, Guest . Much better than the stock one.
I have some questions:
- when to expect an update? i have issues when waking up from sleep... ethernet connection always fail and have to disconnect the cable and put it back in... also
- any solution for the weak wifi signal? i use 5ghz wifi and it can be slower than 2.4ghz ... any DIY or cheap antennas that you could reccomend?
Originally posted by LilSnoop40 View PostQuestion I installed this on my M8S Pro L S912 3G 32G DDR3 LQ it’s ok for this box correct. I feels hotter than when I had stand-alone LibreELEC install is this anything to worry about? I keep the box on its side facing up. Thanks
Guest
Strange one this.spmc gives hd options but doesn't work.kodi doesn't give you options .need more thinking on this I do.
I think my only option left with this Mecool M8S PRo L is to attempt flashing the Magendanz ROM on the random chance it fairs better than stock...
So I borrowed a new mi box 3 just to triple verify there is zero fault with my audio hardware. With that, I am able to see HD Audio options in Kodi and successfully passthrough DTS-HD and TrueHD.
There are currently 1373 users online. 2 members and 1371 guests.
