Thank you elektrik! I think I will try it..
****OFFICIAL Polaroid PMID701c THREAD! root, market, and more!
Originally posted by dovertim View PostThank you elektrik! I think I will try it..
Home Buttons Not Working! Both the HardButton and the screen icon doesn't work!
Polaroid PMID701c
Running Android 2.3 Gingerbread
-installed Root kit manager
-installed Google Market/Play
-removed the Phone.sdk process that checked for cell signal, to improve battery life.
Now the Home icon at the top left corner doesn't do anything, nor does the physical button on the side when pressed.
Is there an app I can install to reconfigure this?
Right now I have to click 'Back' as many times as it takes to get back to the Home Screen which is very annoying.
Anyone else have this problem too?
Thanks Elektrik!
Originally posted by elektrik View Postyes, I had that problems a few times actually. sometimes it would uappen after I installed an application, sometimes it would just 'flqsh bad'. The problems went away when I upgraded to ICS (of course i traded them for a NEW set of problems lol). I would try reflashing. until I get a chance to become intimate with gingerbread (read-elektricity ROM, gb) that was the only way I knew how to 'fix it'.
I will try your suggestion. Bay Area represent!!
Originally posted by demochip View PostThanks for the reply! I just got this tablet from Woot.com for $49.99 and so far I am very satisfied with this tablet's functionality and performance.
I will try your suggestion. Bay Area represent!!Last edited by elektrik; 08 January 2013, 19:16.
Micro SDHC?
Originally posted by elektrik View Postya know it lol. seriously though,it turns out there is a fix for the buttons in a different thread, which I'll incorporate when I make elktricity gb
Also do you know what types of micro sdhc cards are compatible with this tablet? I'm am trying to buy a 32GB Class 10 sdhc, should work right?
Originally posted by demochip View PostCould you link me to where you saw it? This forum's search function isn't very good...
Originally posted by Nougat View PostMine came with 2.3, I upgraded to 4.0 from Southern Telecom. Now I want to go back to 2.3, but when I run the firmware tool and plug the device in to USB while holding the menu button ... nothing happens. Device doesn't power on, just sits there.
Thoughts?
Originally posted by elektrik View PostHold down the power button for about 20 seconds on the tablet with the usb cord disconnected, then try to flash again via the flashing instructions-our tablets have a 'firmware upgrade' mode that doesn't show anything on the screen but puts it in a flasheable state - the PMID701C's are pretty indestructible in that regard...
Originally posted by Nougat View PostNo dice. Holding the power button down boots it into ice cream, then I power down and do the Menu+USB - still nothing. The other thing I'm noticing is that when the device was new out of the box, it would power on automatically when plugged into USB. On 4.0, it doesn't power on automatically like that. Weird.
Originally posted by elektrik View Postok, dumb question, but you've verified the drivers are correct and they work?
I do see a device in devmgmt that "can't start" -- USB Device(VID_1f3a_PID_efe8). But I can browse the USB storage on the device. You're probably right that some part of the driver is not working properly.
I've tried to update the driver, pointing it directly at the UsbDriver folder in the LiveSuit download - it's the same driver, "Code 10, the device cannot start."
I'll have to come back to this later. Thanks for your input.
There are currently 2344 users online. 2 members and 2342 guests.
