- Open GApps Stock Package
- All contents of the Nano Nexus variant
- Open GApps Nano Package
- Google Now Launcher (replaces Lighthome Launcher)
- Google Chrome Browser (replaces AOSP Browser)
- Google Legacy Camera (replaces AOSP Camera)
- Google Desk Clock (replaces AOSP Desk Clock)
- Google WebView (replaces AOSP WebView)
- Terminal app from LineageOS
- TWRP Recovery 3.2.3-0 by TeamWin
- Ported over latest M8S Pro OEM firmware (20180412.194117.V0213)
- Merged in latest M8S Pro L bootloader and device tree (20180803.173707.V0213)
- Updated to TWRP Recovery 3.2.3-0
- Preserves Miracast from OEM firmware
- Latest build from Open GApps (20180830)
- Updated to latest M8S Pro L OEM firmware (20180205.111652.V0928)
- Wake from sleep is now taking the expected 2-3 seconds.
- New build of Mali driver that supports OpenGL 3.2 + AEP
- Clicking on Vision Settings in the setup wizard now works.
- Latest build from Open GApps (20180310)
- Updated to latest M8S Pro L OEM firmware (20171216.102705.V0928)
- Underlying OEM firmware fixed wake from sleep...but it's taking about 28 seconds. It should only take 2-3 seconds.
- Updated to TWRP Recovery 3.2.1-0 based on latest OEM kernel.
- Latest build from Open GApps (20180109)
- Updated to latest M8S Pro L OEM firmware (20171127.165619.V0928)
- Added local update and backup option from Settings->About->System update based on Amlogic stock OTAUpgrade app.
- Latest build from Open GApps (20171202)
- Updated to latest M8S Pro L OEM firmware (20171109.180937.V0928)
- Added additional option (Reboot & Sleep) to global action menu that displays when you press and hold the Power button.
- Fixed issue with external storage not showing up in some applications.
- The Terminal app now shows only after being enabled in Settings->Developer Options.
- Additional support for HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
- Rebuilt TWRP with new V0928 kernel
- Latest build from Open GApps (20171116)
- Nexus splash logo with stock Android boot animation
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- Nano Variant: BURN PACKAGE (930MB IMG file), OTA UPDATE (479MB ZIP file)
- Stock Variant: BURN PACKAGE (1.46GB IMG file), OTA UPDATE (824MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
- This firmware is designed for earlier models of the M8S Pro L with the QCA9377 wireless chipset. If you install it on later (non-LQ) hardware, WiFi and Bluetooth won't work.
- The underlying OEM firmware for this build is pre-rooted, so this is too.
- The updater is signed, and so can be installed in the Update app, the stock recovery, or TWRP. It's designed for incremental updates, since user data is preserved. If you're installing for the first time, you should include a data wipe.
- The safest bet is always to install the full Amlogic burn package with USB Burning Tool. With no reset switch, you can trigger USB detection by typing "reboot update" in a terminal window.
- The local terminal app shows after being enabled in Settings->Developer Options. (This must be revealed by clicking Settings->About->Build 7 times.)
- Flash ROMs at your own risk and always remember to back up your data first. The burn package includes a factory reset.
- Maarten Fonville at Open GApps
- LineageOS
- TeamWin
- Pure Nexus Project
- @GeekBuying_Rep for OEM .img file
- Your support is always appreciated! Just click here.
