[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by trebor View PostWorks with voice remote
Works with ATV Google Play
If not use Aptoide for apps you cannot find.
Look Here
http://freaktab.com/forum/tv-player-...-bt4-1-100mbps
Hi Magendanz
Im new to here and new to ATV and patching etc.
i have just successfully installed both versions of your Firmware and its really nice, however im very noob when it comes to rooted devices etc.
So the Firmware i had before was not rooted and worked fine, but i was curious to try yours too
the problem now is that i cannot run one of the local in country TV apps to stream my subscription as that app looks for rooted devices, and therfore will now not allow me to stream any content.
I tried to install SuperSU but it wont run and says its "busy"
could you explain to me how to unroot this firmware ? or steer me to a post that explains this.
I thank you for your work and time and effort.
I have tried to go back to the previous Firmware i had, but it will now not allow the downgrade and says the file is for a M8S_Pro_L and my device is not a q20x or something along those lines.
The file i tried to revert to is "M8S_PRO_L-ota-20171208.110230.V0928.zip" which was working fine with my local app.
Would be great if i can unroot this device now.
Many thanks
EDIT:
I was able to extract the contents of the ZIP file mentioned above, i then updated the install script file to point at q20x and it was able to restore that Image....Yay!
So im back on the ATV version which is not rooted and have full access to all my apps again.Last edited by bchuter; 06 March 2018, 19:45.
I got this box 3-4 days now, tried several roms and i decided to stay in this one, cause i dont like very much the atv versions. The box seems to work ok but compared to m8s pro ( i also have it with the magendaz nano nexus rom) , i have to mention some things.
First i can tell that this box is not so smooth like the m8s pro. The UX is lower and you can feel it. Takes some more time to open an app and to swipe between the screens, e.t.c
2nd. Not so strong and fast wifi, like the pro
3rd. It s hot. I dont know if this cause some problems but two nights i let lt on, the tv was off, and in the morning the box was freezed and i had to unplug it in order to work again. The first night it was playing a movie and the second i turned off the tv while the box starting the geekbench
4th. While playing some 4k videos from a usb stick, some of them losing some frames. Noticable
5th. There is a difference of ~11k points in antutu v7 between the two boxes (44k vs 55k).
Playstore says that antutu maybe it s not optimized for m8s L but i run it several times and i noticed that there are some 3d scenes in the beggining of antutu, that play on m8s pro but not in L. Thats why the score difference, but i thing that both boxes have the same gpu. L missing drivers?
i believed that the only difference between the 2 boxes was the ddr4 ram vs ddr3 but now i see that maby this model uses differend (cheaper) kind of parts.
I dont believe it s only matters of this firmware. I believe it s a good one (thanx Magendaz)
Coclusion: no serius problems and good price for someone that needs 4k youtube and fhd netflix
P.s. i hope very soon to have an update of this rom
Thanx u once more Mag!
Guest
Changelog (20180310):- Updated to latest M8S Pro L OEM firmware (20180205.111652.V0928)
- Wake from sleep is now taking the expected 2-3 seconds.
- New build of Mali driver that supports OpenGL 3.2 + AEP
- Clicking on Vision Settings in the setup wizard now works.
- Latest build from Open GApps (20180310)
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- Nano Variant: BURN PACKAGE (924MB IMG file), OTA UPDATE (476MB ZIP file)
- Stock Variant: BURN PACKAGE (1.42GB IMG file), OTA UPDATE (807MB ZIP file)
Originally posted by Magendanz View PostChangelog (20180310):- Updated to latest M8S Pro L OEM firmware (20180205.111652.V0928)
Guest
I'm working on TVStock now, and also the M8S PRO release.
BTW, that new Mali driver with OpenGL 3.2 support improved the Antutu score from 44828 to 51208.
Originally posted by Magendanz View PostI'm working on TVStock now, and also the M8S PRO release.
Do we need to setup the box again after the ota update?
Edit:
Updated went good, downloaded and tried to run antutu several times but never had a success.
sometimes the app crashed, some other times it freezed.
Should i install the ota update again?
thanks a lot, Guest - i installed the new update, but i got a bit confused.
Is that correct, that the Android Security Patch level is with the date 01.08.2017 ??
The Kernel Version is 3.14.29, is that correct? (with a date there of 5.2.2018)
Can you please have a look on my AIDA64 information on the anexed pic, if everything is installed correctly, thanks.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Jeffers View PostWill it be OK to install this ROM on Mecool M8S PRO L 4K TV Box Amlogic S912 Bluetooth 4.1 + HS - VOICE REMOTE CONTROL ( 3GB RAM + 32GB ROM ) will the voice remote control work?
Don't want to burn it to my box and have issues.
There are currently 1723 users online. 1 members and 1722 guests.
