[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by jacko View PostAnyone having problems with external hard drives ?
I have a 2gb external hard drives and it keeps crashing when watching films via mx player pro ?
Sometimes the mecool fails to see the contents of the hard drive.
Hi Guys! I just wanted to post a ROM specific issue I've come across with Sixaxis Controller and this ROM that was driving me nuts for days before finding the fix / problem! The problem related to the following error message "Could not find required activity".
Using this ROM I kept getting a weird error message in Sixaxis Controller every time I tried to load a background when editing / constructing custom game touch profiles for individual games! I kept getting the following error message "Could not find required activity" and I wasn't getting to the option for selecting and loading game screen capture as a background! I was just getting the error message! This function is a critical feature of Sixaxis Controller and without it working you just can't create easy or accurate game touch profiles!
It turns out "Sixaxis Controller" and another touch emulation / mapping app I tried "Game Controller 2 Touch PRO" use a normally native ROM gallery app to select and load the background. So turns out with this custom ROM the default gallery app was taken out and is not found so we get the error message and background select and load fails!The simple fix is to just install "Google Photos" and problem is fixed! Backgrounds will now select and load in both apps
Guest Maybe it's worth considering leaving the default ROM gallery app in the ROM build or perhaps including Google Photos in the ROM build to avoid this same issue with potentially other apps producing the same error?
As a side note for those Sixaxis users that may not have come across my other post on here regarding a connection issue with Sixaxis and Wireless Bluetooth controllers on our boxes. For some reason wifi needs to be active to maintain a stable Bluetooth connection. If like me your not using wifi but Ethernet for your network / internet connection you need to turn on portable wifi hotspot to maintain a stable Bluetooth connection otherwise Bluetooth with keep dropping out on you!
Guest. Hi! I just updated to the latest custom ROM version here (20180310) and noticed "Live Wallpaper Picker 7.1.2" was not included in the ROM again? I have installed the APK as a system app and live wallpapers are loading and working just fine! I know the stock ROM doesn't include the live wallpaper picker but is there any reason to not include it in this custom ROM? It's a feature most of us are use to seeing supported! Oh and thank you for all your custom ROM work it is much appreciatedcheers
Please guys i need some help
I installed nani rom on my mecool pro L and all works perfectly except that i cant copy any text from chrome or Gmail app or any other app
When i long press ok button on text or link doesn't show pop up bar for copy, paste or copy link
Is that normal for this rom or what is the problem
I wish to fix this issue.
There are currently 3335 users online. 0 members and 3335 guests.
