On kodi doesnt play at all the netflix addon .
[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by tombraga View Post
Is this the update also for the L Variant? I have the DDR3 LQ box?
My last update i made was with the M8S_Pro_L-V0213_stock-20180830.zip
so i can update this with ota update to the new date 20181111 right?
I also wrote several postings to you Guest about my problem, that i get many times boot loop on starting the system.
But the rom works very fine and smooth when the system starts well.
Thanks for your help.
Originally posted by Spastro View PostHow long does the update normally take for the nano? Tried updating the original lq but it's sitting on the MeCool logo at the start of boot.
Been about 5 minutes. Have I bricked it?
Originally posted by Spastro View PostGot it to work! It didn't even try to update. Second time I tried it did.
Seems to work fantastic for the most part but Randomly rebooting mid video stream.
heat issue? Or somthing else I should be looking at?
Bigger heat sink will improve further, but best solution is a fan under the box in sucking mode as well, then it runs real cool
Loving this update but a couple of issues I'm having.
1. Mx player occasionally goes black with audio only even though I'm using hardware +. Sometimes I can get it back on sometimes I have to reboot. Is this normal? Using neon with patched audio codec etc.
2. Vlc crashes when it opens a stream. I can get into the settings fine but anything else and it shuts down.?Â
3. Kodi only plays sound and not video. Was all fine prior to this firmware.
Is this running 32bit or 64bit OS? When I tried to install Kodi 64bit which I've done in the past it said it wasn't compatible. So I had to install 32bit.?Â
Any thoughts?Last edited by Spastro; 11 November 2019, 09:21.
Guest
You'll need to strip out the environment checks in the update script...which is not without risk. There's usually a good reason that we check to ensure we're running on the expected device and OS.
Originally posted by Magendanz View PostYou'll need to strip out the environment checks in the update script...which is not without risk. There's usually a good reason that we check to ensure we're running on the expected device and OS.
I replaced the build.prop on the box with one from a M8S Pro L, then I could complete the OTA update using TWRP, but I wasn't very happy with the end result.
It didn't give me the usual option to setup, as it does when using burning tool, but it did all that by itself.
Is that normal with an OTA update?
After the rom was installed and running, burning tool still didn't see the box. Would get the message that windows was installing the driver successfully, but no connection.
I finally got it recognized by burning tool on another PC.
Guest
Originally posted by Jancales View PostI finally got it recognized by burning tool on another PC.
Hi Guest, I use a Minix neo A3 air mouse with this box, but after reboot the mouse will not be active.
Simply unplug usb receiver and plug in again, and it works.
Tried different A3 mouse, and they all act the same. The problem doesn't occur with the A2 Lite.
Is there anything I could change in the build properties that fix this issue?
There are currently 4187 users online. 0 members and 4187 guests.
