[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by Magendanz View PostChangelog (20180830):- Ported over latest M8S Pro OEM firmware (20180412.194117.V0213)
- Merged in latest M8S Pro L bootloader and device tree (20180803.173707.V0213)
- Updated to TWRP Recovery 3.2.3-0
- Preserves Miracast from OEM firmware
- Latest build from Open GApps (20180830)
- This firmware is designed for earlier models of the M8S Pro L with the QCA9377 wireless chipset. If you install it on later (non-LQ) hardware, WiFi and Bluetooth won't work.
- Nano Variant: BURN PACKAGE (930MB IMG file), OTA UPDATE (479MB ZIP file)
- Stock Variant: BURN PACKAGE (1.46GB IMG file), OTA UPDATE (824MB ZIP file)
(I have a TWRP backup of the latest stock ROM if that would help you to get the WiFi and Bluetooth chipset working).Last edited by Mandrake; 17 September 2018, 23:40.
I get many times boot loop with the new stock rom, don't pass to android logo and launcher then. I must switch off and switch on so many times my box. But when it enter normal all is working fine. What can be the problem Guest? I already reinstalled 3 times the rom in TWRP.
Same thing with Nano update, i flashed it also.
Bootloop so many times, have to switch off and on several times to get into the system. What happens? With the older rom i had never this problems.... Please Guest give any help. thanks. Your rom works so smoothly on my Mecool box, thanks a lot.
something strange i found out now:
Normally i use the shutdown button from statusbar when i want to switch off my box, i wait for shutdown (red light of box continue), then i cut the power (switch off adapter). In this way i got many boot loops.
Now i tried, not to use the shutdown button of stausbar, only to cut the power. This i tried 4 times and never got a boot loop when i switched on my box again. Why this?? Which explanation?
Is there any problem to cut the power (any harm for the system) without using shutdown button? In Windows we don´t shoot make this, but i in Android i think there is no problem???Last edited by tombraga; 18 September 2018, 22:38.
Originally posted by waylotul View PostI think he might be busy, I been praying for help on the launcher. What hardware version of this box is your again?
With the old rom never had problems, now i get so many times boot loops an the start logo, android logo don´t appear. I cannot understand why, i like the rom of Guest, but this new update gave me lot of headache...
Unfortunately i don´t have more first version of Guest rom, i lost the zip-file. Do you have this yet??
On my old laptrop i found now the M8S_PRO_L-V0928_Stock-20180109.zip file
I think this was the build i had before i installed the V0213_Stock_20180830.
Do yo have other buld between the 2018009 and 20180830 dates??Last edited by tombraga; 25 September 2018, 19:11.
Originally posted by waylotul View PostI have one "update_M8S_PRO_L-V0213_TVStock-20180830.zip" but I have LS version of the hardware.
You don´t have this problem?
Originally posted by waylotul View PostI think I actually used the SD card method today to flash M8S_PRO_L-V0213_Nano-20180830-NOATV.img. It works great! first boot took awhile. After that I used the menu button on my IR Remote and booted to TWRP from the SD Card. Installed TWRP from there. No problems so far.
I already disactivated the automatically boot with the system of many apps with SD Maid Pro, because i thought un app could provoce the bootloop, but not. The problems remains.
Perhaps something is wrong with the new firmware V0213, on former roms Guest used the former firmware V0928 where i never got this bootloops.
I understand that Guest is very busy, but i cannot understand that he don´t speak only some words about my problem. Finally was he, who put this new version online short time ago...Last edited by tombraga; 26 September 2018, 09:01.
waylotul do you think i should reinstall with TWRP the last bootloader which Guest used with the rom of august?
this one:- Merged in latest M8S Pro L bootloader and device tree (20180803.173707.V0213)
I didn't change anything, but again mine is the LS. I think there is a warning about the LQ version. What version is yours?
UPDATE: I CAN use burn card method to install theNano Variant: BurnPackage (930MB IMG file) using the "Menu" button during power up repeadetly pressing it, flashed the update. I CAN NOT install Stock Variant: BURN PACKAGE(1.46GB IMG file) using burn card method.
Something is different there. I booted to TWRP and recovered to OEM I made when I got it. I then repeated both attempts to burn and only the nano would burn. From an OEM image TWRP I made I could install the smaller zip OTA UPDATE (824MB ZIP file). Something up there.Last edited by waylotul; 26 September 2018, 17:24.
Originally posted by waylotul View PostI didn't change anything, but again mine is the LS. I think there is a warning about the LQ version. What version is yours?
There are currently 2848 users online. 0 members and 2848 guests.
