[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by tombraga View Post
I also could install successfully the rom of 30. August, but if i disconnect the box from power (power off really) and switch on again, many times it get on boot loop. But if the system starts normally the build is working fine for me, no problems, no freezings.
I already disactivated the automatically boot with the system of many apps with SD Maid Pro, because i thought un app could provoce the bootloop, but not. The problems remains.
Perhaps something is wrong with the new firmware V0213, on former roms Guest used the former firmware V0928 where i never got this bootloops.
I understand that Guest is very busy, but i cannot understand that he don“t speak only some words about my problem. Finally was he, who put this new version online short time ago...
Guest
Okay, I've created a new thread for the LB variant (BCM4335 wireless chipset) of this custom ROM here. Many thanks to Ewald Bayer for donating the hardware!
Changelog (20181111):- Updated to latest M8S Pro LB OEM firmware (20180803.173707.V0213)
- Latest build from Open GApps (20181111)
- You can enable the nav bar in Settings->Display->Statusbar, but may need to toggle back and forth before it will show.
- The Live Wallpaper service is not enabled in the Amlogic SDK 7.1.
- Nano Variant: BURN PACKAGE (943MB IMG file), OTA UPDATE (491MB ZIP file)
- Stock Variant: BURN PACKAGE (1.22GB IMG file), OTA UPDATE (695MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Magendanz View PostOkay, I've created a new thread for the LB variant (BCM4335 wireless chipset) of this custom ROM here. Many thanks to Ewald Bayer for donating the hardware!
My last update i made was with the M8S_Pro_L-V0213_stock-20180830.zip
so i can update this with ota update to the new date 20181111 right?
I also wrote several postings to you Guest about my problem, that i get many times boot loop on starting the system.
But the rom works very fine and smooth when the system starts well.
Thanks for your help.
Is this the update also for the L Variant? I have the DDR3 LQ box?
Hello all.. Does this Nexus rom supports touchscreen displays? I got one Mecool M8S Pro L 3GB / 32 GB with bluetooth remote and connected it to a 10" touchscreen display trough HDMI but touchscreen isn't working. After I searched on different forums I've found that stock rom doesn't have touchscreen support. It's any way to get touch driver working for this box?
Здравствуйте Магенданц,помогите пожалуйста с восстановлением mecool m8s l (lq) . Загрузил последнюю прошивку из шапки M8S_PRO_L-V0213_Stock_20180830.img в USB_Burning_Tool нажал пуск -пошла прошивка,доходит до 8% и стоп....подскажите вчём причина этой ошибки? В
recovery не входит,с тв нет сигнала,возможно стёр память? Eсть ли возможность вывести её из этого состояния? Рассмотрю любые варианты.Логи
[13:25:43 221][Global][Inf]--Scan usb device
[13:25:43 221][Global][Inf]--Aml scan WorldCup Device
[13:25:43 221][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C2D
[13:25:43 221][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_3672103c& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:25:43 221][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&b7b51d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:25:43 323][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&daf96c6&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:25:43 323][Global][Inf]---------->[Port0]NoDeviceConnected
[13:25:43 323][Global][Inf]---------->[Port1]NoDeviceConnected
[13:25:43 323][Global][Inf]---------->[Port2]Other device
[13:25:43 323][Global][Inf]---------->[Port3]Other device
[13:25:43 323][Global][Inf]---------->[Port4]NoDeviceConnected
[13:25:43 323][Global][Inf]---------->[Port5]NoDeviceConnected
[13:25:43 323][Global][Inf]-------->[Port1]NoDeviceConnected
[13:25:43 323][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26
[13:25:43 323][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_3672103c& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:25:43 323][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&5c43263&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:25:43 323][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&22e1e7b1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:25:43 323][Global][Inf]---------->[Port1]Other device
[13:25:43 323][Global][Inf]---------->[Port2]NoDeviceConnected
[13:25:43 323][Global][Inf]---------->[Port3]NoDeviceConnected
[13:25:43 323][Global][Inf]--Scan USB host controller complete
[13:25:43 323][Global][Inf]--Update data center with HubMap
[13:25:50 235][Global][Inf]--User click open button
[13:25:57 751][Global][Inf]--Image path C:\M8S_PRO_L-V0213_Stock_20180830.img
[13:26:16 799][Global][Err]--[13:26:16 940][Global][Inf]--Parsing burning package
[13:26:16 940][Global][Inf]--Load configuration file C:\Program Files\Amlogic\USB_Burning_Tool\temp
[13:26:16 940][Global][Inf]--Parse burning configuration file C:\Program Files\Amlogic\USB_Burning_Tool\temp\burn_config.xm l
[13:26:16 955][Global][Inf]--Get burning key
[13:26:40 747][Global][Inf]--Catch DBT_DEVICEARRIVAL
[13:26:40 747][Global][Inf]--Scan usb device
[13:26:40 747][Global][Inf]--Aml scan WorldCup Device
[13:26:40 747][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C2D
[13:26:40 747][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_3672103c& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:40 747][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&b7b51d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:40 846][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&daf96c6&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:40 846][Global][Inf]---------->[Port0]NoDeviceConnected
[13:26:40 846][Global][Inf]---------->[Port1]NoDeviceConnected
[13:26:40 846][Global][Inf]---------->[Port2]Other device
[13:26:40 846][Global][Inf]---------->[Port3]Other device
[13:26:40 846][Global][Inf]---------->[Port4]NoDeviceConnected
[13:26:40 846][Global][Inf]---------->[Port5]NoDeviceConnected
[13:26:40 846][Global][Inf]-------->[Port1]NoDeviceConnected
[13:26:40 846][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26
[13:26:40 846][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_3672103c& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:40 846][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&5c43263&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:40 846][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&22e1e7b1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:40 846][Global][Inf]---------->[Port1]Other device
[13:26:40 846][Global][Inf]---------->[Port2]\\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:26:40 846][Global][Inf]---------->[Port3]NoDeviceConnected
[13:26:40 846][Global][Inf]--Scan USB host controller complete
[13:26:40 846][Global][Inf]--Update data center with HubMap
[13:26:40 846][Global][Inf]--Insert new hub4
[13:26:40 925][Global][Inf]--Update hub4 device data
[13:26:40 925][Global][Inf]--Update HUB4-1
[13:26:40 925][HUB4-1][Inf]--Update device path
[13:26:40 925][Global][Inf]--Update HUB4-2
[13:26:40 925][HUB4-2][Inf]--Update device path
[13:26:40 925][Global][Inf]--Update HUB4-3 \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:26:40 925][HUB4-3][Inf]--Update device path
[13:26:40 925][Global][Inf]--Begin thread for HUB4-3
[13:26:40 925][Global][Inf]--Update HUB4-4
[13:26:40 925][HUB4-4][Inf]--Update device path
[13:26:40 925][Global][Inf]--Burning thread HUB4-3 start
[13:26:40 925][Global][Inf]--Update HUB4-5
[13:26:40 925][HUB4-5][Inf]--Update device path
[13:26:40 925][Global][Inf]--Update HUB4-6
[13:26:40 925][HUB4-6][Inf]--Update device path
[13:26:40 977][Global][Inf]--Burning thread HUB4-3 begin run
[13:26:55 746][Global][Inf]--User click start button
[13:26:55 746][Global][Inf]--SetErase
[13:26:55 746][Global][Inf]--Enable burning 1
[13:26:55 746][Global][Inf]--Scan usb device
[13:26:55 746][Global][Inf]--Aml scan WorldCup Device
[13:26:55 746][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C2D
[13:26:55 746][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_3672103c& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:55 746][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&b7b51d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:55 797][HUB4-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000710
[13:26:55 847][HUB4-3][Inf]--CloneImageProxy
[13:26:55 852][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&daf96c6&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:55 852][Global][Inf]---------->[Port0]NoDeviceConnected
[13:26:55 852][Global][Inf]---------->[Port1]NoDeviceConnected
[13:26:55 852][Global][Inf]---------->[Port2]Other device
[13:26:55 852][Global][Inf]---------->[Port3]Other device
[13:26:55 852][Global][Inf]---------->[Port4]NoDeviceConnected
[13:26:55 852][Global][Inf]---------->[Port5]NoDeviceConnected
[13:26:55 852][Global][Inf]-------->[Port1]NoDeviceConnected
[13:26:55 852][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26
[13:26:55 852][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_3672103c& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:55 852][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&5c43263&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:55 852][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&22e1e7b1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:55 852][Global][Inf]---------->[Port1]Other device
[13:26:55 852][Global][Inf]---------->[Port2]\\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:26:55 852][Global][Inf]---------->[Port3]NoDeviceConnected
[13:26:55 852][Global][Inf]--Scan USB host controller complete
[13:26:55 852][Global][Inf]--Update data center with HubMap
[13:26:55 852][Global][Inf]--Update hub4 device data
[13:26:55 852][Global][Inf]--Update HUB4-1
[13:26:55 852][HUB4-1][Inf]--Update device path
[13:26:55 852][Global][Inf]--Update HUB4-2
[13:26:55 852][HUB4-2][Inf]--Update device path
[13:26:55 852][Global][Inf]--Update HUB4-3 \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:26:55 852][HUB4-3][Inf]--Update device path
[13:26:55 852][Global][Inf]--Update HUB4-4
[13:26:55 852][HUB4-4][Inf]--Update device path
[13:26:55 852][Global][Inf]--Update HUB4-5
[13:26:55 852][HUB4-5][Inf]--Update device path
[13:26:55 852][Global][Inf]--Update HUB4-6
[13:26:55 852][HUB4-6][Inf]--Update device path
[13:26:55 899][Global][Err]--[13:26:55 899][HUB4-3][Inf]--Connect path=Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26/P0/P0/P2
[13:26:55 899][HUB4-3][Inf]--Start burning...
[13:26:55 982][HUB4-3][Inf]--------------ERASE BOOTLOADER------------
[13:26:56 012][HUB4-3][Inf]--2-2-0-0
[13:26:56 027][HUB4-3][Inf]-------------Download DDR.USB-----------
[13:26:56 027][HUB4-3][Inf]--Close device handle 0x00000710
[13:26:56 105][HUB4-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000710
[13:26:56 156][HUB4-3][Inf]--2-2-0-0
[13:26:56 156][HUB4-3][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[13:26:56 672][HUB4-3][Inf]--Control write pll reg1 0xd9000000:0x00005183
[13:26:57 188][HUB4-3][Inf]--Write initial succeed
[13:26:57 188][HUB4-3][Inf]--Upload encrypt at 0xc8100228
[13:26:57 188][HUB4-3][Inf]--ulValue = 0xadfc318c
[13:26:57 188][HUB4-3][Inf]--Read encrypt value succeed
[13:26:57 235][HUB4-3][Inf]--Transfer complete
[13:26:57 235][HUB4-3][Inf]--Run at address 0xd9000000
[13:26:57 235][HUB4-3][Inf]--RunInRam succeed
[13:26:57 297][HUB4-3][Inf]--2-2-0-0
[13:26:57 297][HUB4-3][Inf]--CheckFileRunState succeed
[13:26:57 297][HUB4-3][Inf]--runResult:0x 0,paraMagic:0x7856efab
[13:26:57 297][HUB4-3][Inf]--ddrCapacity:0x c00
[13:26:57 297][HUB4-3][Inf]-------------Download UBOOT.USB-----------
[13:26:57 297][HUB4-3][Inf]--ulValue = 0xadfc318c
[13:26:57 297][HUB4-3][Inf]--Download DDR.USB buffer at 0xd9000000
[13:26:57 313][HUB4-3][Inf]--Transfer complete
[13:26:57 313][HUB4-3][Inf]--Download UBOOT.USB buffer at 0x0200c000
[13:26:57 453][HUB4-3][Inf]--Transfer complete
[13:26:57 469][HUB4-3][Inf]--DownCheckPara succeed
[13:26:57 469][HUB4-3][Inf]--Run at address 0xd9000000
[13:26:57 531][HUB4-3][Inf]--ReadCheckPara succeed
[13:26:57 531][HUB4-3][Inf]--Download DDR.USB buffer at 0xd9000000
[13:26:57 547][HUB4-3][Inf]--Transfer complete
[13:26:57 547][HUB4-3][Inf]--DownRunPara succeed
[13:26:57 547][HUB4-3][Inf]--Run at address 0xd9000000
[13:26:59 094][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[13:26:59 109][Global][Inf]--Scan usb device
[13:26:59 109][Global][Inf]--Aml scan WorldCup Device
[13:26:59 109][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C2D
[13:26:59 109][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_3672103c& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:59 109][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&b7b51d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:59 211][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&daf96c6&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:59 211][Global][Inf]---------->[Port0]NoDeviceConnected
[13:26:59 211][Global][Inf]---------->[Port1]NoDeviceConnected
[13:26:59 211][Global][Inf]---------->[Port2]Other device
[13:26:59 211][Global][Inf]---------->[Port3]Other device
[13:26:59 211][Global][Inf]---------->[Port4]NoDeviceConnected
[13:26:59 211][Global][Inf]---------->[Port5]NoDeviceConnected
[13:26:59 211][Global][Inf]-------->[Port1]NoDeviceConnected
[13:26:59 211][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26
[13:26:59 211][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_3672103c& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:26:59 211][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&5c43263&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:59 211][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&22e1e7b1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:26:59 211][Global][Inf]---------->[Port1]Other device
[13:26:59 211][Global][Inf]---------->[Port2]NoDeviceConnected
[13:26:59 211][Global][Inf]---------->[Port3]NoDeviceConnected
[13:26:59 211][Global][Inf]--Scan USB host controller complete
[13:26:59 211][Global][Inf]--Update data center with HubMap
[13:26:59 211][Global][Inf]--Update hub4 device data
[13:26:59 211][Global][Inf]--Update HUB4-1
[13:26:59 211][HUB4-1][Inf]--Update device path
[13:26:59 211][Global][Inf]--Update HUB4-2
[13:26:59 211][HUB4-2][Inf]--Update device path
[13:26:59 211][Global][Inf]--Update HUB4-3
[13:26:59 211][HUB4-3][Inf]--Update device path
[13:26:59 211][Global][Inf]--Update HUB4-4
[13:26:59 211][HUB4-4][Inf]--Update device path
[13:26:59 211][Global][Inf]--Update HUB4-5
[13:26:59 211][HUB4-5][Inf]--Update device path
[13:26:59 211][Global][Inf]--Update HUB4-6
[13:26:59 211][HUB4-6][Inf]--Update device path
[13:26:59 274][HUB4-3][Inf]--Device is removed
[13:27:00 197][Global][Inf]--Catch DBT_DEVICEARRIVAL
[13:27:00 197][Global][Inf]--Scan usb device
[13:27:00 197][Global][Inf]--Aml scan WorldCup Device
[13:27:00 197][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C2D
[13:27:00 197][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_3672103c& rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:27:00 197][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&b7b51d&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:27:00 301][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&daf96c6&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:27:00 301][Global][Inf]---------->[Port0]NoDeviceConnected
[13:27:00 301][Global][Inf]---------->[Port1]NoDeviceConnected
[13:27:00 301][Global][Inf]---------->[Port2]Other device
[13:27:00 301][Global][Inf]---------->[Port3]Other device
[13:27:00 301][Global][Inf]---------->[Port4]NoDeviceConnected
[13:27:00 301][Global][Inf]---------->[Port5]NoDeviceConnected
[13:27:00 301][Global][Inf]-------->[Port1]NoDeviceConnected
[13:27:00 301][Global][Inf]--Host: Расширенный хост-контроллер Intel(R) 6 Series/C200 Series Chipset Family USB ? 1C26
[13:27:00 301][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_3672103c& rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[13:27:00 301][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&5c43263&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:27:00 301][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&22e1e7b1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[13:27:00 301][Global][Inf]---------->[Port1]Other device
[13:27:00 301][Global][Inf]---------->[Port2]\\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:27:00 301][Global][Inf]---------->[Port3]NoDeviceConnected
[13:27:00 301][Global][Inf]--Scan USB host controller complete
[13:27:00 301][Global][Inf]--Update data center with HubMap
[13:27:00 301][Global][Inf]--Update hub4 device data
[13:27:00 301][Global][Inf]--Update HUB4-1
[13:27:00 301][HUB4-1][Inf]--Update device path
[13:27:00 301][Global][Inf]--Update HUB4-2
[13:27:00 301][HUB4-2][Inf]--Update device path
[13:27:00 301][Global][Inf]--Update HUB4-3 \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[13:27:00 301][HUB4-3][Inf]--Update device path
[13:27:00 301][Global][Inf]--Update HUB4-4
[13:27:00 301][HUB4-4][Inf]--Update device path
[13:27:00 301][Global][Inf]--Update HUB4-5
[13:27:00 301][HUB4-5][Inf]--Update device path
[13:27:00 301][Global][Inf]--Update HUB4-6
[13:27:00 301][HUB4-6][Inf]--Update device path
[13:27:00 363][HUB4-3][Inf]--Device is connected
[13:27:00 363][HUB4-3][Inf]--Close device handle 0x00000710
[13:27:00 426][HUB4-3][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&123fa1c5&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000554
[13:27:05 485][HUB4-3][Inf]--0-7-0-16
[13:27:05 485][HUB4-3][Inf]--CheckFileRunState succeed
[13:27:05 485][HUB4-3][Inf]-- low_power
[13:27:05 485][HUB4-3][Inf]--Send command success
[13:27:05 485][HUB4-3][Inf]--Read command status success
[13:27:05 485][HUB4-3][Inf]-------------Download meson1.dtb-----------
[13:27:05 547][HUB4-3][Inf]-- download mem dtb normal 96256
[13:27:05 563][HUB4-3][Inf]--Send download command success
[13:27:05 563][HUB4-3][Inf]--Read command status success
[13:27:05 578][HUB4-3][Inf]--Transfer complete
[13:27:05 578][HUB4-3][Inf]--Send download get_status command succeed
[13:27:05 594][HUB4-3][Inf]--get_status success
[13:27:06 110][HUB4-3][Inf]-------------ERASE FLASH-----------
[13:27:06 110][HUB4-3][Inf]--disk_initial 1
[13:27:06 110][HUB4-3][Inf]--Send command success
[13:27:48 587][HUB4-3][Inf]--Read command status success
[13:27:48 587][HUB4-3][Inf]-------------Download _aml_dtb.PARTITION-----------
[13:27:48 587][HUB4-3][Inf]--0-7-0-16
[13:27:48 587][HUB4-3][Inf]--download store _aml_dtb normal 96256
[13:27:48 587][HUB4-3][Inf]--Send download command success
[13:27:48 602][HUB4-3][Inf]--Read command status success
[13:27:49 977][HUB4-3][Err]--Return buffer=media error 1 at seq 16, resend 3
[13:27:49 977][HUB4-3][Err]--Download file failed, sequence 1
[13:27:49 977][HUB4-3][Inf]--Failure : 1, FailureMax : 3
[13:27:50 540][HUB4-3][Err]--Return buffer=media error 1 at seq 16, resend 3
[13:27:50 540][HUB4-3][Err]--Download file failed, sequence 1
[13:27:50 540][HUB4-3][Inf]--Failure : 2, FailureMax : 3
[13:28:31 058][HUB4-3][Err]--usbWriteFile len=30720, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[13:28:31 058][HUB4-3][Err]--Download file failed, sequence 1
[13:28:31 058][HUB4-3][Inf]--Failure : 3, FailureMax : 3
[13:28:31 169][HUB4-3][Err]--[0x30403003]UBOOT/Partition _aml_dtb/Download buffer/Data tranfer error
[13:28:31 169][HUB4-3][Inf]--Close device handle 0x00000554
any chance firmware for the mecool pro L s912 nano will work for the sunvell t95z plus s912?
*update*
so i flashed the img that was a nexus nano for the alfawise s92 and it worked on the t95z plus but get go any further than the welcome screenLast edited by blaze2051; 12 January 2019, 09:56.
There are currently 3279 users online. 1 members and 3278 guests.
