[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
After trying both the Nano and the Stock Nexus ROMs, I went back to the Mecool ROM using your "M8S_PRO_L-ota-20180205.111652.V0928-fixed" via OTA update from a USB drive. I wish there was a way to force this box to 'always STAY ON'..
Any ideas on that please?
Thanks for all of your hard work!
Originally posted by thewarmone View PostAfter trying both the Nano and the Stock Nexus ROMs, I went back to the Mecool ROM using your "M8S_PRO_L-ota-20180205.111652.V0928-fixed" via OTA update from a USB drive. I wish there was a way to force this box to 'always STAY ON'..
Thanks for all of your hard work!MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
What do you you mean "always stay on"?
Any script to force it to stay powered on all the time?
Thank you
Hi everyone !
Thanks Guest for your work !
I have tried it and found a few unexpected behaviours :- Casting does not work
- Spotify playlists : plays 5/6 songs and then sounds cuts off, changing sound settings on box and tv do not change anything. You get the sound back when you try another playlist
- Plex : some issues whith some videos, it hangs while the Mi Box (Android 6) is able to play.
- I have isolated two problematic files. If you point me in the right direction I can provide me info
- Airmouse (MELE F10 Deluxe) not working
I used the following firmware : update_M8S_PRO_L-V0928_TVStock-20180310
Regards,
AlexLast edited by seyaralex; 10 May 2018, 23:09.
Regards,
Alex
In tv roms airmouses possible not work so better flash this threads' rom and test again or make your question to the right thread .
Originally posted by alexei_gp View Post
I have the same problem like Tombraga with Magisk i have a ctsprofile false in the nano stock of magendanz rom...Can anyone help me with this issue?Thank you for reading me an waiting for the reply.
Originally posted by Oops View PostHi, I have a problem with Plex. I have a black screen or freeze screen When I playing movies. Sound playing with a strange additional sound (click, click... click, click...). Work fine with my Phone (redmi 3) or my samsung active tab 8"MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Oops View PostI don't know. Where can I check this?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
You can check the codecs of your media using the free Windows app, Mediainfo. However, these Android boxes play almost all of the available codecs, except videos encoded with VC1, and then the video stutters.
Format : AVC
Format/Info : Advanced Video Codec
Profil du format : [email protected]
Paramètres du format : CABAC / 5 Ref Frames
Paramètres du format, CABAC : Oui
Paramètres du format, RefFrames : 5 images
Identifiant du codec : V_MPEG4/ISO/AVC
Durée : 2 h 31 min
Débit : 3 778 kb/s
Largeur : 1 920 pixels
Hauteur : 1 080 pixels
Format à l'écran : 16/9
Type d'images/s : Variable
Images par seconde : 23,976 Im/s
Espace de couleurs : YUV
Sous-échantillonnage de la chrominance : 4:2:0
Profondeur des couleurs : 8 bits
Type de balayage : Progressif
Bits/(Pixel*Image) : 0.076
Taille du flux : 4,01 Gio (81%)
Bibliothèque utilisée : x264 core 155 r2901
Originally posted by bajann View PostVC1 is ok on android 6 amlogic s912
I don't have a S912 running Android 6 to test.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2863 users online. 1 members and 2862 guests.
