[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by Jeffers View Post
A very good question
As the buttons on the remote work I thought it was paired.
What kind of pairing gets voice control to connect?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
That remote is a combo IR/Bluetooth. You need to go into settings/ more settings then turn on Bluetooth. It will then start searching for Bluetooth devices. Depress the center "OK" button while also depressing the minus "-" buttons. Hold the remote only a few inches from your box. It should pair, and then your Voice will work.
Put remote couple of inched from Mecool and held down "OK" and "-", light on remote flashes about every second for a while then stops.
Voice still not working.
When the remote pairs, what should happen, message displayed, light flashes faster, entry in bluetooth settings, what should I be looking for, how can I tell if the remote bluetooth has paired or not?
A silly question, what am I supposed to be talking to Google now, Google Assistant?
I have an alert in the bar at the top of the screen asking me to try the Google Assistant, do I need to set this up?
Turned on Bluetooth.
I have an alert in the bar at the top of the screen asking me to try the Google Assistant, do I need to set this up?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yes. The easiest way to verify if your remote is in Bluetooth, is to place your hand over the end of your remote where the emitter is and see if it still works.
Putting my hand over the end of the remote stopped any key depressions getting through, so I guess Bluetooth is connected.
Following up the Google Assistant alert didn't get me anywhere, still no voice control, I'll have to google some more.
Putting my hand over the end of the remote stopped any key depressions getting through, so I guess Bluetooth is connected.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am not sure what you mean by "stopped any key depressions getting through, so I guess Bluetooth is connected". If you have your hand over the end of the remote and you can't do anything with the remote, it means that you remote is NOT paired. Go into settings/more settings and under Bluetooth, it should show if your remote if paired......
It looks like my remote won't pair via bluetooth.
This is what happens when I try and pair:-
"Turned on Bluetooth., bluetooth is searching
I misunderstood your post, "The easiest way to verify if your remote is in Bluetooth, is to place your hand over the end of your remote where the emitter is and see if it still works." I took that to mean if it doesn't work then bluetooth is connected.
Put remote couple of inched from Mecool and held down "OK" and "-", light on remote flashes about every second for a while then stops.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
One more tip. Remove the batteries from your remote, wait a few seconds and re-insert the batteries. Then follow to pairing procedure again, it should pair.
It hasn't because if I cover the end of the remote an depress a button it doesn't work.
Did that no joy, I don't know what I should be looking for to indicate Bluetooth has connected.
It hasn't because if I cover the end of the remote an depress a button it doesn't work.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
When you go into settings, then more settings, and enable Bluetooth, it should start searching for any Bluetooth devices. If you have a cell phone with Bluetooth, turn it on and see if your box detects it while it is searching for Bluetooth devices.
My phone Bluetooth is set to off.
I go into settings, more settings, Bluetooth shows as Disconnected
Click on Bluetooth, Bluetooth shows as On, with the following Available devices:-- Geoff's Shield
- KD-49X8305C (Sony TV)
- 67:54:E7:2E:CE:
0 (I don't know what this is) had to put a double ":" to stop it being turned into a smiley, that didn't work the smiley should be a "D"
I do a Bluetooth refresh on the Mecool and details displayed stay the same as the above
I go to with a couple of inches of the Mecool with the remote, press and hold OK and minus keys, light on remote flashes approximately every second for approximately 20 seconds (timed on my phone)
Nothing gets displayed or changed on the TV screen, stays the same as the above, with the exception that item 3 has moved to the top of the list, so it now looks like this:-- 67:54:E7:2E:CE:
- Geoff’s Shield
- KD-49X8305C (is my Sony TV)
The buttons on the remote work, but if I place my hand in front of the remote the buttons don’t work
I am out of ideas so any further suggestions would be much appreciated
I went back into Bluetooth to take some pics with my phone and the available devices have changed to this:-- Geoff'Shield
- 44:1C:A8:4C:BA:C6
- 40:3C:CC:5F:79:CC
When I press the voice contol button on the remote I get the screen displayed in the 3rd attached pic, rarely it takes 1 press of the button to get this displayed, more often it takes 3 or 4 quick presses of the voice control button to get this screen displayed, how many presses it takes is inconsistent
I have looked up the Bluetooth ID on my Mecool and it is 22:22:58:0c:e8:fcYou may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
A step forward into more unknown.
Without knowing how a Bluetooth device has appeared in my list of Available devices, called RemoterATV3
So I paired with it, see Pic
When I cover the end of the remote with my hand button presses on the remote get through, means my remote is connected via Bluetooth?
Couldn't wait to try out voice input, now when I press the voice control button on the remote I get "System UI has stopped, X Close app"??
How would I go about fixing this?You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Not to your error message, I really don't know how to solve that. Start with a Google search. Now that you can pair your remote, do a complete system reset from the settings, and start over. Don't add any apps until your remote is paired and functioning, that SHOULD tell you if your Bluetooth is causing an issue with your system UI (user interface)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yes, that RemoterATV3 IS your remote that is paired and connected. First question would be, can you replicate pairing your remote. The weird numbers/letters are MAC address of your Bluetooth devices.
Chose English (United Kingdom)
Chose Let's Go and Set up as new
When entering email address Mecool rebooted.
Now when I choose Let's Go get error message "Settings has stopped" or "Settings keeps stopping" then choose close app and now stuck in loop,
To get out of loop went back up to choose language and changed it back to "English American"
Reset complete, now set about pairing remote on Bluetooth
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 4002 users online. 1 members and 4001 guests.
