[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by Geero View Post
Thanks my friend for replying
That happens with all apps not only chrome
But anyways what other browsers you think i should install?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
You are correct, you can't copy and paste, at least I have not found a way.
So.... Is it like a problem with this firmware?
That means that everyone having the same problem?
Is it possible to to go back factory software? And where can i find the original software
I'm using Mecool m8s pro L old remote (no voice function)
Cheers
Thanks bro for reply
CheersMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by zenix View Post
This thread is not for tv rom. And as we can see , you use tvstock rom .
In tv roms airmouses possible not work so better flash this threads' rom and test again or make your question to the right thread .
Originally posted by seyaralex View Post
Not sure what you mean, I downloaded the ROM from this thread so .... yep, I think it's relevant
This rom you use is ATV variant so read my answer again .
From this thread you cannot download the rom you already use because is for non atv variants . So try download this https://1drv.ms/u/s!AoqocX31ecnXga1FxH5jlJmCO1FldQ and flash it . Everything working fine then .
You wrote: " I used the following firmware : update_M8S_PRO_L-V0928_TVStock-20180310"
I downloaded that firmware from the first post on this thread. And this was not the rom that I already used, since I used that one to replace the ugly MeCool mod they shipped the box with.
And I am happy with that version, except for the bugs. I downloaded that Nano one, but it's not what I am looking for.
Zenix, I am not sure what you mean.
Hi All,
I'm new to the whole android TV stuff.
I've recently bought a M8S Pro L which comes with some voice remote but I don't like the Android TV firmware, I just want basic android on it like whats on my phone.
I've tried loading this ROM onto it but it always errors out with the message:
Found: M8S PRO L, M8S PRO L-userdebug 7.1.2 NHG47L 20180417.150752.V0213
E3004: This update package is intended only for the M8S PRO L.
E:Error in /udisk/update_M8S_PRO_L-
(status 7)
Installation aborted.
I did this using the OTA install which says current version is 91243021
can anybody help please?
If you have the LB revision (look at the sticker underneath it), i'm afraid you have to sit and wait like the rest of us. For the LQ, you can put the Magendanz firmware on it - to get around the error message you need to edit the update script in the zip version. But if it's a new box, it's likely an LB, and then there's no alternative .. yet ..
There are currently 2587 users online. 2 members and 2585 guests.
