[ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
Originally posted by bchuter View Post
Would also like to know
Originally posted by balnik View Post
Unroot by using a file manager like ES File Explorer (just turn on root access in the settings). Go to the system folder and select “xbin” delete “busybox” and “su”. Go back to the system folder and select “bin” delete “su”. Restart the device and it will all be done.
Guest i love your rom, all is working so great, i don´t have any heating or freezing problems and the apps are running very smooth.
But i have two questions to you, perhaps you can help:
1) Sky Go Germany released a new update of the app and now it is not possible more to run this app on rooted devices,but i need root. So i changed successfully from SuperSu to Magisk 16.0. Now i can hide my Sky Go app and it is running again. But there is other problem, that the app don´t accept to watch on external tv monitor (as i do with HDMI connection). The former version of the app worked and did not give this error, but now i can see the picture running with a big message in front of it.
Have you a possibility to bypass this in your future rom-update to make the app thinking that is no external monitor connected?
As for example on fones or tablets it is running well, because they have their screen integrated as well.
2) The Magix 16.0 is installed correctly, but when i check the SafetyNet Test, the ctsProfile did not pass, why? And what means it? See the anexed picture.
On my Lenovo Yoga Tab 3 Plus with LineageOS 14.1 installed (also rooted) i have installed the same Magisk 16.0 verison and the SafetyTest pass all ok.
Thanks for your help.
Originally posted by Jeffers View Post
Any chance of a reply?
Don't want to burn it to my box and have issues.
Am I able to use this ROM, if I loose voice remote so be it?
Or, anyone recommend a ROM I can use on this box, Mecool M8S Pro L 3GB/32GB with voice remote?
Guest could you help me please with this problem, that the new Sky Go app (after update) don´t allow more the external Screen connected with HDMI (mirroring) with the Mecool box.
Perhaps you can find a solution? Would be very greatful.
Here some more informations: https://www.didgeridoohan.com/magisk...kHideSafetyNetLast edited by tombraga; 20 March 2018, 10:33.
My Mecool appears to go asleep, when I switch to the HDMI channel it is connected to the 'No Signal' message is displayed, blue light is on. I have tried every key on the supplied remote, including short and long press of power and OK keys, but nothing appears to wake the box up. Anyone advise me on how to wake the box up?
Before it gets in this state the screen saving moving about the screen clock is displayed.
Originally posted by Jeffers View PostMy Mecool appears to go asleep, when I switch to the HDMI channel it is connected to the 'No Signal' message is displayed, blue light is on. I have tried every key on the supplied remote, including short and long press of power and OK keys, but nothing appears to wake the box up. Anyone advise me on how to wake the box up?
Guest Hello, I am using the (Nano Variant: BURN PACKAGE). I installed an android tv netflix for 1080p(works great) , but noticed it has a grey bar at the bottom while playing a movie. This doesn't happen in Plex or Prime Video. Anyway to fix this, Other then that this rom works great! Thank You.
Edit 3/26/18:
Managed to get rid of the grey bar, but I lost the [Status bar/Navigation bar] option in settings doing so, don't think i ever used it.Last edited by Krumm; 27 March 2018, 17:15.
Originally posted by tombraga View PostGuest i love your rom, all is working so great, i don´t have any heating or freezing problems and the apps are running very smooth.
is it not possible to "make" something in your rom to simulate that the HDMI-cable connection don´t exists and the box is not a box but some device with internal monitor? Would be great and so great help. thanks
a similar thing as Magix does with unhiding option of the app which is fooling the sky go app that the device is not rooted. And now we need something which fools that there is no external monitor but internal monitor.
Guest why don´t respond me??Last edited by tombraga; 12 April 2018, 12:20.
Originally posted by Krumm View PostGuest Hello, I am using the (Nano Variant: BURN PACKAGE). I installed an android tv netflix for 1080p(works great) , but noticed it has a grey bar at the bottom while playing a movie. This doesn't happen in Plex or Prime Video. Anyway to fix this, Other then that this rom works great! Thank You.
Edit 3/26/18:
There are currently 848 users online. 0 members and 848 guests.
