NEW - MK908-Android-4.2.2-jjhmod-v2.1 Alpha - Download
Originally posted by Chakumo View PostWifi/speed = Ok?
BT = Ok?
Video playback 720p/1080p = Ok?
OTG port On/Off = Ok?
Antutu test = ? (reboot Yes/No)
Camera (logitech web cam, Skype) = Ok?
V3.0 hardware produced probably late may 2013 received mid june
Version 2.1 kernel 4.0 720p fast
BT = Ok? NOT TESTED
Video playback 720p/1080p = Ok? 720p Framing over LAN only v1.2 produced NEARLY stable results over wifi, the same movie was always used for test.
OTG port On/Off = Ok? OK
Antutu test = ? (reboot Yes/No) UNABLE TO TEST DUE TO GOOGLE PLAY REBOOT
Camera (logitech web cam, Skype) = Ok?[/QUOTE] NOT TESTED
GOOGLE PLAY REEBOOTS, NOT GOOD.
Originally posted by Lowteck View PostV3.0 hardware produced probably late may 2013 received mid june
Version 2.1
kernel 3.1 720p 800 mhz
BT = Ok? NOT TESTED
Video playback 720p/1080p = Ok? NOT TESTED
GOOGLE PLAY REEBOOTS, NOT GOOD.[/QUOTE]
Originally posted by TheFonz View PostSo is this ROM/Kernel meant for V1 models of the MK908? Is there any easy way to tell what version of the MK908 we have?If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
I found out I have the MK908 V3 (2013.05.13) and I tried the v3 kernel from the link you supplied, however I am not sure what's going on.
I don't know if it's kernel, ROM or hardware related but my screen will blank out for 1-2 seconds and this will happen randomly though constantly.
Any ideas? What's my options here because I'm at the end of my rope and I am close to ditching the MK908.
Originally posted by TheFonz View PostI found out I have the MK908 V3 (2013.05.13) and I tried the v3 kernel from the link you supplied, however I am not sure what's going on.
Any ideas? What's my options here because I'm at the end of my rope and I am close to ditching the MK908.If my work benefits you and you want to help out the cause, feel free to
No problem, I'll give it another go with the revised version for v3 hardware.
Originally posted by Orak View PostThis happened to me out of the box on one of my tvs, I switched to a different tv and it worked, it also might be the hdmi cable or power supply.
else. It could be the actual TV that's causing the issue. Thanks though - I think you are right!
So here's the setup I had and it worked fine: MK908 USB -> Laptop with HDMI plugged into computer monitor
When I moved it to my TV it started blanking out, this was how it was running: MK908 USB -> Power point with HDMI plugged into TV.Last edited by TheFonz; 18 August 2013, 12:46.
Originally posted by TheFonz View PostJust a little worried about my stick blanking the screen, haven't seen it mentioned anywhere
else.
I am really wondering how those guys with v3 HW reported success with some other FWs - including different jjhmods with alternative kernels - I have had no luck with any other combination except the out-of-the-box jjhmod universal v2.0. That is why I am eagerly waiting for the chefs to actually receive their v3 HW sticks and look closely into this problem of V3 HW...
Originally posted by TheFonz View PostNo problem, I'll give it another go with the revised version for v3 hardware.
I have tried various ROMS and the only ROM that doesnt do it is the Finless ROM, I have tried my stick in 2 TV's and get the same behavior, I am not sure if mines is a V3 or not but as its new I think it will be giving I have the same problems as you, I also get the same problem using the stock 0802 update from geekbuying's blog post,
Soemthings not right somewhere, I've only owned the stick for 4 days now and the performance has been poor.
Originally posted by hoabycsr View PostHonestly I don't have tons of linux experience with adding modules and such.. I could build you a kernel with that module turned on in the kernel, but it will break build-in wifi and possibly bluetooth as I cannot seem to find a way to add it as well as keep the ap6210 enabled. I could also try to build that module for you from my sources so you could see if that would work. If you get a chance, try the new kernel.. I did enable a couple usb wifi config options in there.
i tried the new kernel without any luck... but i found the driver for 3.0.36+ and i dont know it just dont work :/ i tried everything .
i really dont care about the bluetooth and thw internal wifi if you can make a kernel for the 8192cu.ko
that will be amazing!!!
please let me know if the wifi disconnecting problem is fixed on this rom. thankshttp://www.MayBeSmart.info
The Best Tutorial Site!!!
There are currently 2387 users online. 2 members and 2385 guests.
