[ROM] Vorke Z6 / Tanix TX92 TVStock Nexus ROM (Android TV 7.1)
Hey Magendanz, sorry for the question, but have you modified any audio codec or something like this in this build? Because bluetooth audio looks like those PS2 / PSP games when emulated on a mobile phone. Yes, I am user from the M8S Pro, I tested this firmware on my MS8 Pro secondary and it went well, I was even shocked. But unfortunately had the audio problem, as my monitor has no sound, it is need to use bluetooth speakers.
Guest
Changelog (20180119):- Based on the latest Shiningworth All-in-One firmware (Vorke_Z6-20171221).
- Underlying OEM firmware now includes settings for Auto Framerate and Superuser Root Mode.
- Fixed stuttering problem with Bluetooth audio on QCA9377 wireless chipsets.
- Includes front LCD display service to show time and status.
- Updated kernel modules for game controllers and added initialization code in init.amlogic.board.rc.
- Added kernel module for Broadcom Bluetooth USB dongles.
- Updated to TWRP Recovery 3.2.1-0 based on latest OEM kernel.
- Updated to latest OpenGApps build (20180119).
- Google Cast service works from Chrome browser, but apparently requires Google license to work from Android apps
- Recommendations will show in the status bar by design. If you want it always hidden, just uncomment "persist.sys.useTvStatusBar=true" in build.prop.
- If holding reset button to boot to recovery, release after 10 seconds and then wait for almost a minute. It will eventually get there.
- TVStock Variant: BURN PACKAGE (1.10GB IMG file), OTA UPDATE (571MB ZIP file)
Originally posted by Magendanz View PostChangelog (20180119):- Fixed stuttering problem with Bluetooth audio on QCA9377 wireless chipsets.
Guest
I noticed strange behavior when trying to search.
Before the update, when the "Search" button on the TV remote control was pressed, the box immediately began to listen to the commands. Now if you press "Search" 1 time, then the box does not listen, but only shows the text. And only with a quick double-click box begins to listen.
Secondly, you can not use the cursor to select a search from the keyboard. In this case, the voice search is launched immediately.
I attach the video where I show how it works.
It seems direct tv for tablets doesn't play well with this ROM, can you suggest a non-androidtv based ROM that'll work. Loved this ROM but need the cable
Well, I'm partial to the Nano and Stock variants of this custom Nexus ROM, which are non-ATV. http://freaktab.com/forum/tv-player-...android-tv-7-1
Hello dude,
Thanks for the Rom, just a question, i have take the img version, for updating
1. Copy the .ZIP to a TF Card or USB memory.
2. Plug it to your TV Box.
3. Open UPDATE APP already pre-installed.
4. Press "Select" and choose the .ZIP file.
5. Wipe Data & Cache
6. Press "Update" and wait.
This way ?
Originally posted by Magendanz View PostChangelog (20180119):- Based on the latest Shiningworth All-in-One firmware (Vorke_Z6-20171221).
The OTA update can be run from the Update app (Settings->About->System Update), TWRP recovery, or stock recovery. The .zip file can be placed on an SD card, USB flash drive, or just downloaded to a directory on the eMMC.
The burn package must be flashed with a male-to-male Type A USB OTG cable, using USB Burning Tool. Or, you can stick it on an SD card and use BootcardMaker.
There are currently 1887 users online. 30 members and 1857 guests.
Most users ever online was 7,737 at 14:33 on 01-16-2020.
