Kimdecent B13 - MK812 - Jesurun NX003
    Here is my Neomode Custom Rom for the Kimdecent B13 - MK812 - Jesurun NX003.
    I call it NEOTV CROM 1.8 Beta. Why 1.8 ? The Last Rom was made by Finless Bob it has 1.7 Beta.
    He had has no Time to make a new one. So I have made a cream for it with the Number 1.8 Beta.
    It is an Android 4.2.2 Based Rom with a functional AV Output.
    He had removed all the Bloadware and add my goodies.
    Main Features:
    Android 4.2.2 Rom
    Rooted
    Init.d Support
    Various Speed Up Tweaks
    Software:
    Stock Launcher
    My Android TV Launcher
    Ultra File Explorer
    Reboot App
    YouTube
    SuperSu
    Xposed Framework Netflix Tweak if needed
    I have tested it and it Works :-)
    Updated Version SU Fixed !
    Regards
    Neomode
    Thanks Neomode! Will test it tomorrow when I get home.
      this should be based on the firmware from 05/18 android 4.2.2
      RK android tool here we meet again
        AW: Kimdecent B13 - MK812 - Jesurun NX003
        Did you need an Update Img?
        Neomode
          Neomode
          i just wanted to flash it via RK batch tool as one img file
          clean flash
            Let me ask which problems you got with RK Flash Tool?
            Neomode
              Neomode
              i had one tv stick bricked with it , probably becouse of a different bootloader
              ok how should i flash it
              click run or erase IDB first than run
              also i have edited the parameter to an extra 500mb
              is this correct
              0x00300000@0x0011C000(userdata),0x00002000@0x0041C 000(kpanic),0x00100000@0x0041E000(system),-@0x0051E000(user)
                Must be correct but I can not confirm it because I am not at home.
                Before Flash erase IDB. By the Way the App Size Flash is 1 GB.
                Neomode
                  Neomode
                  everything went fine but the rom doesnt have root access , checked with root checker
                  when i click Supersu it says binary needs to be updated press continue
                  and when i try to update the normal way it fails
                    You are connected to the Internet?
                    When I am Home will test it.
                    Neomode
                      Neomode
                      yes i am
                      can i update the binary manually somehow
                        Only over the updated. As I say i will look at it when at home.
                        Neomode
                          also take a look at the play market compatibility if you throw up another release
                          a lot of apps are not showing in the market
                          everything else is fine
                            mate are you working on fixing the root
                            sorry to disturb but i am impatient becouse i need it as soon as possible
                              No 1080p??
                              No 1080p. That's too bad. No one got a working 4.2.2 kernel for this stick. need to ask Finless where he get the 1080p kernel for his wonderful ROM's.
