1.First you download and save www.http://pan.baidu.com/share/link?shareid=3731893369&uk=1731287152 the .img file to your computer.
2.You then download, save and inzip the attached file to your computer.
3.Open the RKBatchTool.exe file.
4.In the opened window press the button to the right of the "FW Path" line, then choose the .img file with the firmware.
5.Plug the USB plug of a USB - MicroUSB data cable into your computer(better connect av out or hdmi to later monitor the loading of firmware, although not absolutely necessary) . Press and hold the reset button on the TV stick, then plug the MicroUSB plug into the TV stick. Only after doing that release the reset button.
6.The connected devices tab n.1 on the RKBatchTool window should turn green. I assume the RK3066 driver is installed. It should be since you already flashed the ROM previously.
7.Press the "Upgrade" button and wait. After the upgrade is finished wait for the stick to make all the changes and reload (the process can be be observed on the tv). Done.
The Root instructions will follow as soon as I find a place to upload a 20+MB file (the forum does not allow it).
