Kimdecent B13 - MK812 - Jesurun NX003
    Originally posted by jeevas.v View Post
    No 1080p. That's too bad. No one got a working 4.2.2 kernel for this stick. need to ask Finless where he get the 1080p kernel for his wonderful ROM's.
    i dont think he is getting it but making it
    also you will fry the stick without cooling on 1080p kernels
    i really like this rom i got 9800 points in antutu with AV output
    if only he got his hands on this rom
      NO Issue with 1080p at all.
      You are wrong with the 1080p with respect to cooling.
      I've been running my Minix neo X5 and MK812(B13) with true 1080p rom 24/7 with xbmc/skype/ youtube/cheapcast etc with no issues at all. No heatsink and it won't even get more than barely warm.
      I know that finless bob don't compile the kernel. Either he uses available 1080p kernels or patched kernel from others. Don't know if he does binary patching himself.
      Antutu score will go down slightly with 1080p. But I'm not too worried about that as I'm not going to compile the kernel or do hardcore gaming with the minipc.
        mine gets pretty hot but maybe that's how it is supposed to be becouse of its aluminium case
        i dont care about the 1080p kernel , with upscaled 720p looks great too
        i just miss some other things like pinch to zoom (finles has a way of doing this with the third button on the mouse)
        auto hide status bar , rkremote control support and the new patched libstagefright but it may be already in the stock rom
        and ofcourse the usual root and market compatibility
          Not much difference in Temp betweeb 720p and 1080p.
          Yes you are Right that you can feel the heat a lot more in MK812/B13 than other plastic models. The reason is Aluminium is more conductive. That is actually more beneficial as more heat is radiated out. But this behavior has nothing to do with 1080p. The temp is almost the same between both 1080p and 720p.
            i would like more to have overclocked kernel than it will make sense to use the 1080p
            neomode any update on the root ?
              Yes today the Update will come. Sorry was busy the last Time.
              Neomode
                still nothing ?
                  Uploading right now.
                  Neomode
                    Neomode
                    i will flash it right now and give you feedback
                    thanks mate
                    can i flash only system.img or you recommend the whole rom
                      AW: Kimdecent B13 - MK812 - Jesurun NX003
                      Flash the hole system should be better.
                      Neomode
                        good news
                        finally supersu is working great
                        i have updated the binary with success
                        i am still getting cannot get whitelist/modules when uninstalling apps but i think i can fix that if i uninstall xposed framework or just enable it
                        thanks again a lot
                          do you happen to know how i can change LCD density to a bigger value than 160 but keep the Tablet UI
                          i can change it to bigger in build.prop but it always switches to phablet/phone mode
                            Hello,
                            I put on my MK812 this software, but XBMC won't work.. I tried two versions, but it won't work..
                            It won't even start, just show black screen and then shut it and show me normal android pc..
                            How should i fix that ?
                              Originally posted by andy91 View Post
                              Hello,
                              first time it always crashes becouse it is in the ram
                              try restarting the device and open again
                                I restarted device several times and it didn't help. Then it won't show even black screen
