[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
    Hi there guys and girls, one more rom/fw for you all!
    This is a simple one this time!
    Many thks to gearbest for sending me the device to play
    Many Thks to my beta tester trebor
    READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
    NETFLIX FHD (ANDROID TV VERSION ) ONLY WORKS ON L1 BOXES, SO IF YOURS IS L3 YOU KNOW WHO TO BLAME... NOT ME FOR SURE...
    Changelog V1:
    • Based on latest ota 20171030
    • Cleaned lots of stuff...
    • Added TWRP
    • It should have a better cpu usage/ram.
    • Cpu temp should also be better.
    • Unrooted ( Yes now you can install magisk or whatever you use to root, use the included "Update" app to flash it! )
    • General optimization and how the ram is used, should better now.
    • Permissions fixed.
    • Double press on Home button bring the APP Switch Menu ( App Kill Menu)
    • Status bar Auto hide ( Dont ask for Navigation bar because you wont get it )
    • Working ATV google remote control!
    • Install Netflix Android TV version from store...
    • Netflix FHD Android TV app, install from Playstore ( Only on L1 boxes, on L3 ones is needed to sideload the mobile version and of course it will be limited to SD only )
    • Netflix 5.1 Sound ( Needs testing since i don't have a way of testing it )
    • 4k Youtube support!
    • Updated DTV App to the latest one.
    • FTMC Build 31.
    • Some audio mods ( Needs Testing )
    • Settings menus working ( VPN can be added... )
    • Added lots of Kl's
    • initd.d support.
    • Added google cast, ( Will only work with youtube... )
    • Xbox360 wireless Gamepad, original and Chinese clones?! ( well it works with my clone adapter... )
    • PS3/PS4 gamepad support(only with cable...)
    • Added Dragonrise USB HID game controllers.
    • Optimized some animation stuff!
    • And other little stuff...
    • And of course all the other ATV mambo jambo...
    Bugs V1:
    • Cant add a shortcut of the DTV app to main screen because of is app name th.dtv... it needs to have a min of 3 letters before the "."
    • I bet you guys/girls tell me if they are more
    Want to buy me a beer?
    Download:
    Install instructions:
    • DON'T UNPACK THE ZIP
    • Use the included "Update" app that is on stock rom, CHOOSE "Local" on the app.
    • Or just boot to recovery and flash it....
    • THIS WILL DELETE ALL YOUR DATA...
    1ยบ BOOT TAKES AROUND 5 MINUTES!
    THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
    USE AT YOUR OWN RISK!
    Enjoy it!
    Is this p212? So i can install it on t95x?
      nop, this one is for S905D (yes is the same platform as S905X... p212 but not totally the same)
        You are great! Awesome!!!
        A quick question, this time it can be installed as a local update or we have to use amlogic burning tool?
          Local update
            Many thanks. We have a Telegram group (spanish language) with over 600 users of Mecool's K(I-II-III) with DVB support.
            You can view and join @mecoolki right away.
            We were waiting for this because stock roms had a lot of bugs. Mainly we use LibreElec but Android is important too if you wanna view Netflix and Youtube in HD-4K. We'll test it this weekend.
            Thank you again for your pretty work
              Thanks!!!!!!
                Does it work on the S905X platform?
                • superceleron
                  superceleron commented
                  Editing a comment
                  Nop unfortunately !
                Thanks for rom but Can you rename the DTV app, like MyDTV or something like that so it can be put on main screen or is not that easy? I Wonder if TV app repo would work like it does on my nvidia shield tv to add apps to main screen
                  thanks!
                  I currently have NOT stock ROM, BUT, SCV2 ROM: Android 7.1.1 - SCV2
                  "Install instructions
                  can I do update/local from SCV2 ? or, do I need recovery flash ? or, either ?
                  sorry, not clear from instruction if update/local is supported/advise on non stock ROM
                  thanks for your work
                    Up and running, working great, just a shame can't get DTV app on home screen,
                    one problem I have found is when I press epg button on remote it now opens up live channels app which is no good when in the DTV app when you need the epg guide, can this be fixed in the remote.conf file thanks
                      Link in post#1 is for "... KIII Pro Here at Gearbest", it's meant to be KI, yes?
                        thanks for the ROM, installed via OTA/local, minor hiccup, it 'hanged'? after 'done processing script file'(1), waited about 30 min, then , powered off
                        rebooted fine, setup OK, paired Moto kb, failed to pair Moto mouse (mouse worked during pairing, then, pairing failed? maybe needs new battery ? bt kb works OK
                        just scanning TV, updating apps, looks good, Thanks
                        (1)
                        installing ZIP file
                        installing ZIP file
                        check for digest
                        skipping digest
                        target
                        patching image uncoditionally
                        format /data
                        = wipe cache
                        script succeed result 1.000
                        format cache ext4s
                        format cache ext4s
                        wpipe data without /data/media
                        done
                        format cache ext4s
                        Done processing script file
                        /wait 30 min, power off/on/
                          Originally posted by Jake360 View Post
                          Up and running, working great, just a shame can't get DTV app on home screen, one problem I have found is when I press epg button on remote it now opens up live channels app which is no good when in the DTV app when you need the epg guide, can this be fixed
                          thanks
                          can this be fixed? thanks.
                            Yes can be fixed, in a future update!
