thanks
[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
superceleron i know you are a very busy dev but Is the next update coming soon to fix epg button mapping and also try and get DTV app to appear on main screen, and also see if you can get MyTvOnline app integrated, I have tried to install mytvonline my self but can't get it to install, tried renaming package, install via system but no luck.
thanks
I use my unit sparingly, don't have 4K TV, just watch catch up TV, and, stream music to HiFi via optical cable, don't think my unit is 'running hot', haven't noticed - but, once or twice, it has locked up, needing power supply off/on reset
I was told to re-do thermal paste bonding between heat sink and CPU, did you also do that also, is that a 'good idea' ?
Originally posted by abbots View PostI use my unit sparingly, don't have 4K TV, just watch catch up TV, and, stream music to HiFi via optical cable, don't think my unit is 'running hot', haven't noticed - but, once or twice, it has locked up, needing power supply off/on reset
Originally posted by alex980 View PostFirst of all thanks for this great rom.
I have only one single issue for now.
5.1 HDMI Passthrough is not working. I tried to set it to HDMI RAW, but not matter what I set up, my Denon Receiver is only getting a 2.0 PCM signal.
Same with Appls like KODI, Prime Video and Netflix.
Is there a fix or a known issue, or did I just something messed up?
Damm it fried my box, stuck on boot screen, I fitted a cooling fan but it was too noisy so I tried to find an alternative live feed from board that I can add a resistor inline from power source to fan to lower voltage and speed, it worked but I must of touched and shorted out board somewhere, tried alsorts to get it working but it won't go past boot screen.
will have to save for a new box
Originally posted by Jake360 View PostDamm it fried my box, stuck on boot screen, I fitted a cooling fan but it was too noisy so I tried to find an alternative live feed from board that I can add a resistor inline from power source to fan to lower voltage and speed, it worked but I must of touched and shorted out board somewhere, tried alsorts to get it working but it won't go past boot screen.
superceleron are you willing to implement TvheadEnd server in the next version?
Would love this feature to watch Live (tuner) using the Live TV app. And to combine it with IPTV .
Live TV: https://play.google.com/store/apps/d...gle.android.tv
TVirl: https://play.google.com/store/apps/d...stari4ek.tvirl
Tvheadend : https://play.google.com/store/apps/d...nnes.tvheadend
I've been using this rom for a few weeks. My thougths about improvement:
1. Lack of DTV apk shortcut on main screen
2. Epg button which would be turning on epg
3. Channel up/down is reversed
4. Multichannel audio is not working
5. Video on netflix sometmes freezes on 99% and only exit to previous menu and reentering solve this
6. On my unit dtv app is not searching all channels comparing to old basic dvbt tuner
7. Dtv apk is not quite beauty, maybe there is some alternative?
8.Dtv button could be opening the dtv app
9. Some untranslated words in main screen, for example: "loading aplication info" in English instead of Polish language
But anyway good work, keep onLast edited by kamilek; 20 February 2018, 18:09.
Is there any inactivity time out settings...?
Last few days, I power up KI, and just have it 'idle', it shuts down after a couple minutes?
If I use it, and, run something, it doesn't switch off.
If I just power on, and, do nothing h, KI switches off.
don't think I've noticed that earlier. Don't have screen saver enabled.
Might try enabling s/s.
Originally posted by kamilek View Post4. Multichannel audio is not working
Receiver always gets a 2.0 PCM stream from the box.
Are there any ROMs out there where this works?
Or is there a fix for this?
superceleron
There are currently 1955 users online. 0 members and 1955 guests.
