[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
    dazed
    I added DDR4 support. IMG has yet to be compiled
    Edit:
    @dazed
    andbroe
    download: test build
      Fails with this when I try
        This is a Windows problem. Try a different UBT version
          Which version you suggest? I've tried v2.1.6, v2.1.7.3, v2.2.0. I have no problem flashing this boxes firmware with v2.2.0. I've been using that for a while with other boxes and it's always worked
            I have the exact same error message
              MaverickFDO
              I can't do anything with the above error. There is no information that indicates a successful connection between the box and the PC, nor about the percentage progress during the burn process.
              I will write a script that removes the key protection of the eMMC memory and resets the eMMC to its delivery state. You then have to test the new bootloader first..
                MaverickFDO
                There is successful connection, then I load the .img file and press start, but the flashing process stops after 5 seconds in the first step.
                  please post the burn log or video of it
                    Sure, I will do it later
                      Its gets to 1% then fails
                      [2021-05-27 17:27:31 979][HUB1-4][0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
                      Video
                        Video
                        Thx
                        1. Download this aml_autoscript and copy it to the mSD card (FAT32 partition).
                        2. Press the RESET button, turn on the box and hold the RESET button for 3-4 sec.
                        3. Remove the mSD card from the box and repeat the UBT update
                        Warning - This script removes the KEY protection of the eMMC storage and deletes the entire content, including the bootloader!
                        EDIT: Please test another build
                          Thx
                          Still having issues
                            Still having issues
                            I posted an update above (under EDIT). Have you tried it?
                              Tried the update and now it passes the Download DDR.USB step, but fails on Download U BOOT.USB at 4%
                              Error: [0x10302001]Romcode/Switch status/Check connect/Enum device error
                              Log
                              Video
                                Log
                                Video
                                Thanks for the log. Use UBT v. 2.1.7.3 and try again. DDR timing is now correct, full 2G were initialized.
                                [19:05:08 244][HUB2-4][Inf]--Run at address 0xd900c000 [19:05:08 245][HUB2-4][Inf]--RunInRam succeed [19:05:08 722][HUB2-4][Inf]--runResult:0x 0,paraMagic:0x7856efab [19:05:08 722][HUB2-4][Inf]--ddrCapacity:0x 800
