[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by thamie View Postmy k1 pro is freezing up on startup with peeping sound, got the same issue on starting in TWRP. then i tried using burning tool using a old img but couldn't connect to K1. is there a way still to rescue the box or is it dead? thank for your help.
I think from memory it is the top USB port closest to SD Card Slot
If not it is the one under that one.
Toothpick reset button to be pressed whilst powering on.
Keep holding reset until it is recognised.
If that fails start the USB Burning Tool and then do the toothpick reset.
I'm sad this box is not supported anymore because it's not certified. It has a decent SoC and a nice processor and memory, but it doesn't support Android TV and even with efforts of the ROM developers, sooner or later some apps just stop working and the box becomes useless. I bought this box hoping to had a DVB-T2 capable box, Netflix, Youtube, etc, but then now it doesn't support Netflix, sometimes youtube crashes, Disney+ is not available, etc. I tried Coreelec but the Netflix experience is not the best and sometimes fails if you use the DTV tuner before opening Netflix. This ROM was the last hope for this box to be useful, but I understand the developer can't do much for it because of certification issues.
For Mecool KII Pro S905D-LPDDR3-2G / bcm4335 WiFi.. i managed to create a functional ATV9 ROM. Except for the internal DVB tuner (AVL6862) everything works so far. Tvheadend is pre-installed, external tuner support is conceivable..
The firmware is still under development, but will be ready soon
Originally posted by bumerc View PostFor Mecool KII Pro S905D-LPDDR3-2G / bcm4335 WiFi.. i managed to create a functional ATV9 ROM. Except for the internal DVB tuner (AVL6862) everything works so far. Tvheadend is pre-installed, external tuner support is conceivable..
Regards
PicapauGalaxy Note 3 : stock (4.4.2) ROM
Cubot GT99 : stock ROM with crossbreeder
Pipo M6 3g : FreaktabROM v1.0.0
There are currently 3033 users online. 0 members and 3033 guests.
