[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
Originally posted by bumerc View Post
I got the right wifi chip added but can't add the pass for the wifi because keyboard never pops up, plugged a keyboard and mouse into the box and even after adding the pass for wifi pressing enter does nothing. Will randomly reboot/crash, sometimes to that image above.
@bumerc: I have exactly the same situation as dazed - firmware was flashed fine (but only without option "Erase bootloader"). The device is booting and at the Android setup screen (language selection) after few seconds it reboots itself to Android Recovery with this info:
Droidlogic/braun/braun
9/PPR1.180610.011/20210320
userdebug/test-keys
Use volume up/down and power.
Can't load Android system. Your data may be corrupt. If you continue to get this message, you may need to perfrom a factory data reset and erase all user data stored on this device.
Edit: I've flashed it again, this time with "Erase bootloader" option enabled. Still got the same problem.
Edit 2: If you're fast enough to select the language and gp further then it's working fine afterwards.Last edited by uqx; 29 May 2021, 15:47.
Originally posted by MaverickFDO View PostThis box is really useless without certifications and without a good ROM, I think that is the end. I'll throw it away.Last edited by looun; 20 June 2021, 09:31.
There are currently 3553 users online. 0 members and 3553 guests.
