[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
oops, I foolishly enabled 'update system apps' in aptoide
so now all my catch up tv apps, 9now, sbs, etc crash
Google Play told me I need to uninstall updates and revert to factory
It seems to do so in GPlay, but fails to do so on GPlay services, with admin leave warning...
What's best way to recover? Re flash the SC ROM from page 1? Or?
Originally posted by abbots View Postoops, I foolishly enabled 'update system apps' in aptoide
Thanks!
doing it now. Last night I actually re flashed, but, couple of tv catch up apps still not working, one is crashing, one wants an update, though none is available.
I can't find Google drive app to transfer apks from tablet to KI, what's best way to transfer apks from tablet, I'm using myappsharer, copy to PC, SD card, tv box
//later//
SBS on demand app woes:
app used to work till I stuffed up by 'upgrading' some system apps from aptoide
flashed ROM again, app keeps crashing
reset to factory, app keeps crashing
removed app, installed, keeps crashing
etc, etc
gave up....
switched box on this morning, tried, it's working OK now
all's good again, thanks for great ROM and your helpLast edited by abbots; 22 April 2018, 02:04.
I recently purchased Mecool ki pro. I want to update only dtv app with the settings you made in your firmware. Like showing clock on tv screen. Is it possible to update only dtv app? Where can I get that?
Ahem, dumb question, how to record live TV bcast?
I can start DTV app, select from EPG, enter, all good, set to record
do I need to leave KI switched ON for recording to happen? or is there(where?) sleep mode?
but, when I switch TV off, HDMI turns off KI ?
how to do?
and, what is the recording setting if I want program or whole TS?
Hello Superceleron
Not able to go back to stock room I tried to update of stock firmware through update app and local update, but getting this error i tired to close this error bu no button working on remote at this time. Can please helpYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by ayyappan80; 27 April 2018, 03:53.
I installed this ROM but it does not let me type - It would not open the virtual keyboard, anywhere. I managed to install a different virtual keyboard, that is less convenient, but even now I cannot find a way to get down from the search box to the search results, to pick one. I am using the home screen search.
Is it just me? Is there a way? A solution?
There are currently 1862 users online. 0 members and 1862 guests.
