[ROM] Mecool/Acemax KI PRO SCV1 ATV - Android 7.1.2 ( Android Tv Version )
thank you.
can answer someone who is sure ?
Originally posted by drdedus View PostI read that is very easy to install this firmware.
if I want to go back to original firmware is it easy too?
is there any "local update" option so I will install original firmware easily back?
Originally posted by Jake360 View Post#superceleron are you updating the rom with the remote mapping fix and maybe mytvonline apk I posted
thanks, few beers coming your way
superceleron what modifications we have to do to the zip so we can go back to the original firmware?
Thanks .using it more than a week .its works great on my box. only problem is that my wifi was not working it automatically disabled .i had this problem on stock ROM too. is there any tweak to fix it or reset wifi controller.beside this you need to update DTV app to the latest version . because many DVB-S channels of SONY package on asia sat has updated their to latest version and K1 pro DTV aap no longer open the channels. most of other cheap receivers already received Software update to fix it. we need also for K1 pro. I email to videostrong for the same but they did not reply.
Originally posted by babarlhr View PostThanks .using it more than a week .its works great on my box. only problem is that my wifi was not working it automatically disabled .i had this problem on stock ROM too. is there any tweak to fix it or reset wifi controller.beside this you need to update DTV app to the latest version . because many DVB-S channels of SONY package on asia sat has updated their to latest version and K1 pro DTV aap no longer open the channels. most of other cheap receivers already received Software update to fix it. we need also for K1 pro. I email to videostrong for the same but they did not reply.
There are currently 2041 users online. 1 members and 2040 guests.
