CX919 - 4.2.2 - Finless ROM 1.5
    Bluetooth not working
    Hello Finless Bob,
    First off, thanks for the awsome ROM! Everything works great except for the Bluetooth, some message popping up all the time about the massstorage can be removed and the boot image (which is not a big deal but just would like to point it out).
    When I bought the stick with the stock ROM I had no issues with the Bluetooth and was working fine with my BT keyboard and Logitech receiver that is hooked up to my speakers. Since I flashed this ROM with different kernels that were provided I can't pair any devices nomore.
    What I do and what happens:
    - Turn on the device (yeah no shit I really do this! )
    - Go into settings
    - Turn on Bluetooth (tried with both the On/Off switch and the tick box just to rule this out)
    - Serach for devices
    - Click on the device I want to pair to
    ! Now here is where it SOMETIMES goes wrong
    - Device tries to pair but isntead turns off BT and turns it on again
    ! Other scenario from the explanation mark above
    - CX-919 asks me to put in a 4 or 6 digit code and hit enter on the keyboard
    - Screen with the above freezes for a bit after I hit enter (normally would get rid of that screen right away)
    Now I can change the devices name before I do all of these steps (default name is rk30sdk). It changes the name accordingly but when I perform the above steps and the device shuts off the BT and turns it on again it alsow resets the devices name back to the default rk30sdk name.
    Is no one else experiencing this problem or is just no one else using BT devices? Couldn't find anything about it in this thread.
    Than there is this little thing where the device keeps saying that I can remove the mass storage or something but I can't reproduce that at this very moment so that is either solved by itself or will come up later so don't worry about that.
    About the boot image: flashed 1080p kernel and the 1080p image. Shows up the correct size the first 2 seconds or sow but gets smaller after that. Doesn't affect anything just wanted to put it out here.
    After all my 'complaining' I would like to state that the rest I tried like ethernet and the off switch in the bar work AWSOME :-)!
    Best regards from the Netherlands,
    BRamBoNL
      My bugs
      Hi all my Bluetooth problems are I can only send a photo to the cx-919 by bluetooth if I keep moving the mouse wile the transfer is in progress.if I don't keep the mouse moving the Bluetooth freezes & stops working...Also when I connect a usb hard drive it takes ages to connect & never shows up in the storage setting so theres no way I can unmount it, it shows up fine on my other cx919 finless 1.4 rom 4.1,..Oh & does anyone no if theres a way of removing the google search bar from the home screen
        it blows upward
        Originally posted by vikidroid View Post
        @andyjwang, this cooling method is ok, but, afaik, it is wrong position! that is HDD cooler, and vents are blowing in wrong way - down, not up as stick is positioned? or you reversed them?
        but, in any case - good idea!
        I didn't change the flow. But it's blowing upward.
        However I did encountered 2 freezes since then. Not sure it's heat related as the stick wasn't hot at all.
          hm, i have that same hdd cooler, but it blows downward (from POV of your picture). about freezees - i'm not right person to ask! ;-)
            geekbuying firmware link
            Originally posted by Temporel View Post
            @Bob or @anyone who knows.
            Can you give me a link to the CX919 on geekbuying.com that can run this ROM ?<
            Thank you.
            HI guys: We have pushed the factory to release a Real 1080P firmware for the CX-919 quad core tv sticks. CX-919 a rk3188 base quad core tv sticks, with external […]
              720P may be more stable than 1080P
              Originally posted by MARIANOTE View Post
              can somebody tell me the better kernel to be usable? without problems? in your experience ...
              thanks
              If you don't care about 1080P then Finless 1.5 720P is pretty stable. If you want to try 1080P use a cooler fan to cool your CX-919 down. As far as which kernel to use, I like the 800Mhz one.
                Adding a heat sink on top of it
                Originally posted by andyjwang View Post
                I went back to 1.5 800mhz and 1080P but encountered freeze issue (overheat).
                So I use the dual cooling fan to cool it down. (see photo)[ATTACH=CONFIG]3125[/ATTACH]
                CX-919 simply sits on top of the dual cooling fans (used to be the cooling fans for the hard disk)
                So far it is doing a great job. I did not have the gut to cut the plastic cover to install the heat sink as others suggested.
                I found an old heat sink on an older motherboard. Put it on top of it. Have not seen any freeze since.Click image for larger version
                  Please read this why android 4.1.1 is the best rom for gamer:
                  http://www.freaktab.com/showthread.php?5318-CX-919-4-1-1-Finless-ROM-1-4&p=91910&viewfull=1#post91910
                  hope one day this will be fixed in android 4.2.2
                    I found an old heat sink on an older motherboard. Put it on top of it. Have not seen any freeze since.[ATTACH=CONFIG]3132[/ATTACH]
                    Nice rig haha. I have one cool block laying around so could do this but before I reflash and have to install everything again I would like to know if this 1080p 800MHz kernel has Bluetooth working or that the Buetooth problem is not kernel related but ROM related (which I believe it is ROM related unfortunatly...)
                      Bluetooth doesn't work on 800 mhz 1080p
                      Couldn't enable it. But I am not using it. I use dla, bubbleUpnp, and rkremotecontrol.
                        actually it's working (strange thing earlier it refused to enable itself)
                        It's working. I will check more to see if I can upload or download any file.
                          these are links to their blog. I want to buy the actual device from geekbuying.com but they ghave many different model unlike all the others I bought from the past.
                          Thanks anyway.
                            Confirmed that Bluetooth is working
                            I did received 3 test files from CX-919.
                              Update with screen shot
                              Yes, it (BT) Click image for larger version
                                Yes, it (BT) [ATTACH=CONFIG]3154[/ATTACH]is working.
                                Thanks for trying! Going to flash that kernel and see if that all works for me.
                                EDIT:
                                So I tried flashing the 1080p kernel with 800MHz. Bluetooth seems to be a bit more stable than on the Simon 1080p kernel but not as it should be. I could connect to my Logitech device that is connected to my speakers and play sound but I could still not connect to my keyboard. Well I could pair my keyboard but it just would not connect after I paired it, kinda weird...
                                Some other thing is that changing the language from the standard English to Dutch seemed to give some extra problems. When I was in English the Bluetooth worked as described above. Changing the language to Dutch would screw it up even further and nothing in the Bluetooth would work anymore. Seems language dependent for atleast what I tried so far and believe me I checked it several times switching between the languages. Goint to try this when switched back to the Simon 1080p kernel once more.
                                Besides, XBMC stutters on that kernel and I don't like using the XAF build with MXplayer although it solves the stutter problem in XBMC. My girlfriend doesn't like movies without Dutch subtitels so using the built in XBMC subtitle program is awsome, with MX player I think MIGHT be able to have subs but if it will work with a movie from XBMC (which I seriously doubt) it is such a hassle.
                                Going back to the Sam 1080p kernel AGAIN (I reflashed for 10 times at least with 1.5 haha) to get a nice XBMC experience with Dutch subs.
                                Would be realy nice if Finless could see if he could fix this.
                                Last edited by BRamBoNL; 03 September 2013, 16:55. Reason: Don't want to spam here so combined update
