CX919 - 4.2.2 - Finless ROM 1.5
Big Improvement
Flashed last nite with the 720p no oc simon kernel and 4gb partition. I let rom boot up and settle in. Did not try wifi. Then I flashed cwm. Thank you for the note about waiting to flash it after rom boots once. So first thing I test after turing on wifi is my bandwidth. I have no issues. Wifi is same up-down as with 1.4. Next is xfinity cable app. Played and worked well.. Next is netflix. Last nite it worked perfectly.. Then this morning I get cant connect to server error. Reboot stick. Try again and it works. As far as rest of the rom goes. I have had no locks or freezes. Streaming 1080p Test videos through youtube looks the best I have seen so far. I agree netflix has issue with 4.2.....not the stick. Anyway, thank you very much Bob for all that you do. I feel like I have a new stick...lol
Stick freezes - when reading Flipboard
Originally posted by andyjwang View PostI will try the kerneljjh-800mhz-1080p.img or kerneljjh-800mhz-720p.img, may be all of them later.
My Reported issues were using stock 1080P kernel.
Originally posted by andyjwang View PostI am currently running Finless 1.5 with kerneljjh-800mhz-1080p.img. Encountered "system hung". Had to reboot by power it off and on.
Originally posted by Finless View PostIf the box in RK batch tool is green then your already in flash mode!
Quit trying to use switch and just flash the ROM.
Sometimes this can happen with a bad flash. From that point on it will just go into flash mode.
can you tell me if wifi problems are resolved? i see some comments about this and im not sure what kernel is usable for good wifi work, is the only thing im waiting!
thanks!
PD: some link to flash CMW for make a nandroid backup, 1.4 is working good and need to backup! thanks
Originally posted by andyjwang View PostI am currently running Finless 1.5 with kerneljjh-800mhz-1080p.img. Encountered "system hung". Had to reboot by power it off and on.Originally posted by nbhnohome View PostBetter PSU and air circulation are what you need. Try running Antutu with current setup to see if the system freezes or reboots itself.
Looking into an small active cooling solution and better power supply.
Sent from my Pipo M6 using Tapatalk 4.
Wifi Performance
I'll start by saying wifi is finicky on the CX-919. Changing roms and kernels on a PC with the router 6 feet away everything looks good. As soon as I move the CX to where I want to use it, speeds drop off with signal strength.. Speeds on other devices (tablet, laptop) get 25mps up and 5 down anywhere in the house. I was using an iPazzPort mini keyboard until I realized it was causing wifi interference. A logitech mouse seems to not cause a problem. Using the default flash settings (simon 720) I get 4 /5 up at the location I want to use it. With the stock 720 kernal I get 10/5.
Originally posted by Bock View PostI'll start by saying wifi is finicky on the CX-919. Changing roms and kernels on a PC with the router 6 feet away everything looks good. As soon as I move the CX to where I want to use it, speeds drop off with signal strength.. Speeds on other devices (tablet, laptop) get 25mps up and 5 down anywhere in the house. I was using an iPazzPort mini keyboard until I realized it was causing wifi interference. A logitech mouse seems to not cause a problem. Using the default flash settings (simon 720) I get 4 /5 up at the location I want to use it. With the stock 720 kernal I get 10/5.
I've posted a lot of valuable information in the following thread.
Which USB to RJ45 Adaptor for T428? Do they need Drivers?
Can any of the dev guys confirm that the kernels support uvc/v4l ? Upon connecting my webcam (that works under ubuntu) /dev/video0 is created dmesg says
<6>[ 129.080889] usb 1-1: USB disconnect, device number 3
<6>[ 131.680873] usb 1-1: new high speed USB device number 4 using usb20_otg
<6>[ 131.920912] usb 1-1: New USB device found, idVendor=0ac8, idProduct=3420
<6>[ 131.920981] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
<6>[ 131.921031] usb 1-1: Product: Venus USB2.0 Camera
<6>[ 131.921068] usb 1-1: Manufacturer: Vimicro Corp.
<6>[ 131.925132] uvcvideo: Found UVC 1.00 device Venus USB2.0 Camera (0ac8:3420)
<6>[ 131.929692] input: Venus USB2.0 Camera as /devices/platform/usb20_otg/usb1/1-1/1-1:1.0/input/input4
but skype/camera/hangouts or any other program can't seem to find it.
I did lsmod and don't see uvcvideo module loaded. Also i get some errors like this (and i chmod to 777)
<6>[16160.854236] qtaguid: ctrl_counterset(s 0 10056): insufficient priv from pid=408 tgid=349 uid=1000
<3>[16160.875984] init: sys_prop: permission denied uid:1013 name:media.cfg.audio.bypass
<3>[16160.876227] init: sys_prop: permission denied uid:1013 name:media.cfg.audio.mulLast edited by pivanov; 28 August 2013, 15:59.
Hi guys,
I have not installed the Find Rom yet because I think is quite difficult, im not very skilful, but I have an issue with this little CX-919.
Even if I use xmbc or another player to play a film, the film doesnt goes smooth. It seems as the image jumps and it is not possible to see any film.
I have also tried copying the avi file to the sdcard but it goes exactly the same.
Do you thing that installing Findless rom will be better for watching films?
Ty!
stability
freezez
i have random freezes with 1.5 finless rom and simon 1080p kernel, have to reboot when i get it.. its disturbing, is it kernel related?
1.4 is a masterpice..
thinkin about restoring 1.4 and trying that with simon 1080 p kernel..
no word about this from the developers?
i will post back if the freezes accur on 1.4 then i think its the kernel itself..
i have tried 1.4 with simon kernel 1080.. works flawlessly.. i dont know why 1.5 is messing with my headCHEERS 1.4 rom
Random freeze
Originally posted by phozac View Posti have random freezes with 1.5 finless rom and simon 1080p kernel, have to reboot when i get it.. its disturbing, is it kernel related?
There are currently 1947 users online. 1 members and 1946 guests.
