CX919 - 4.2.2 - Finless ROM 1.5
Originally posted by rdavidowski View PostHi Bob
I have installed the Rom with 1080 overclocked to 800mkz. Best rom I have experienced so far.
The good:
video:
Netflix works 100% tested for over 2 hours. No problema!!! Tested XBMC, for what I used it its working fine. I am realy not a fan of this application so do not take my opinion to heart.
Video Conferencing:
My Logitech C170 works 100%. Tried Skype; working 100%. Also tried Hangouts again 100%.
Performance: Being overclocked to 800mhz and stick handled without incidents for hours. Much better than the stock kernel selected by default. No heat issued either.
The Bad:
Hulu Plus does not work. And this is something that the community should work with. Netflix and Hulu are the two most used streaming apps used in the USA. And this sticks main purpose is streaming content to the TV so these two apps are a must. Sorry to say it but Strauzo has it working on his 4.2.2 ROM so I do not think is Hulu's compatibility with Android 4.2.2 the problem. It has something to do with whatever code the Chinese did to android 4.2.2 And also Hulu is working on my Galaxy S4 running 4.2.2 no issues.
Please work this Hulu issue out and for what I am going to be using this CX919 stick; which is streaming and video conferencing over Skype would be 100% working solution.
Again thanks for all the developers that worked on achieving this level of maturity for these RK3188 sticks compared to stock.
rdavidowski
PS. Can anybody confirm what other webcams are working with this Rom. I would like to have more resolution than my C170 currently offers.If my work benefits you and you want to help out the cause, feel free to
http://www.hoaby.com/android/donate.gif
thanks Hoabycsr
But already tried that apk for Hulu and it also does not work. It plays the ads and then it start buffering and never brings the video.
Still would be nice to make the official Hulu app work. Hey it is working on Strauzo's Rom so it must be something with the factory Rom on 4.2.2. It worked very well on factory 4.1.2. Observing the way how the app works I think it has to be something with the app not being able to play the adds. Because if you do not hit the "ok" button you can hear the program playing in the background. Can it be an ad-blocker on the host file? I have had this exact behavior when adding ad-blockers to any android phone, Hulu stops working because it can not play the adds.
rdavidowski
rdavidowski
Personally I like 4.1 better.If my work benefits you and you want to help out the cause, feel free to
Thanks for the update finless, I tried 2 combinations.
Since I got a 1080p TV I firstly tried the 1080p kernel + 1080p boot image.
The boot image didn't fill up the screen (rikomagic.com) and even the animation.
Performance was kinda bad in my opinion and very slow and the device became hot.
I didn't use any overclocked kernels. And all of a sudden wifi became really slow and streaming wasn't watchable.
Then I tried 720p kernel + 720 boot image and all went well. Fast responsive, xbmc 12.2 worked fine but 720p video from YouTube I noticed some framedrop or whatever you call it. Not unwatchable but sometimes you notice it. SD video works very well.
Thanks for all the hardwork and to the kernel developers.
how to change volt.fstab
Originally posted by DiSrUpTeR View Postflashed it, and looks good, touchscreen working.
rom setup:
kernel_simson720
boot_720
cwm recovery.
strange thing is when you check storage in the settings it shows sd and external sd fine
but the native explorer and ES Explorer can't acces the internal SD.
external is shows and can be accesed.
even after some reboots its not there.
Am i missing something? (yeah, internal sd)
Mark
Update: edited the volt.stab and made the external sd act as internal (got 16gig now).
update 2: logitech c270 cam doesn't work, terratec aureon dual usb works, skype installs but can't make a call, and wifi speed seems slow.
Hello to all,
I am currently using the previous finlees ROM with my CX-919, but have noted that there are some queries about heat problems and slow wifi...
So, I would like to know before flashing this new ROM 1.5 if these little problems (Heat and WIFI) are true or if it's better to wait for a Fix?
Some users also have mentioned, that the 800 version can raise the temperature of the CX-919 and that the 1080 version is a little slow, so which version is better and safely to use, the 720 one?
Thanks for your help!!
Originally posted by nybom View PostI use the defaults set by Bob in the flash tool. When watching Netflix, the system freezes after a couple of minutes of movie. Any ideas?If my work benefits you and you want to help out the cause, feel free to
There are currently 2063 users online. 1 members and 2062 guests.
