Mecool M8S PRO L Blue Tooth Voice Control 3/32GB Amlogic S912 A7.1 YT 4K Netflix HD Dual WiFi BT4.1 100Mbps
    Click image for larger version  Name:	20180118094235_34520.jpg Views:	1 Size:	76.7 KB ID:	703252
    Specification
    Brand: MECOOL
    Core: Octa Core
    CPU: ARM Cortex-A53
    GPU: ARM Mali-T820MP3
    Model: M8S PRO L
    RAM Type: DDR3
    System: Android 7.1
    Processor: Amlogic S912
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Decoder Format: H.264,H.265
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Video format: 4K,ASF,AVI,DAT,FLV,H.265,ISO,MPEG1,MPEG2,MPEG4,RM, RMVB,WMV
    Bluetooth: Bluetooth 4.1
    Language: English,Multi-language
    Other Functions: Airplay,DLNA,Miracast
    Power Supply: Charge Adapter
    RJ45 Port Speed: 100M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Package size (L x W x H): 17.90 x 11.50 x 6.50 cm / 7.05 x 4.53 x 2.56 inches
    Package weight: 0.4200 kg
    Product size (L x W x H): 10.20 x 10.20 x 2.10 cm / 4.02 x 4.02 x 0.83 inches
    Product weight: 0.1100 kg
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x Bluetooth Voice Remote Controller, 1 x HDMI Cable, 1 x English User Manual
    Gearbest
    That is awesome, with a Bluetooth VOICE remote included, for that price!! Videostrong keeps raising the bar for the other manufactures to follow.
      Can save a few Bucks
      http://freaktab.com/forum/advertiser...455#post703455
        Originally posted by trebor View Post
        Yes, been drooling over it........ Lord knows, I DON'T NEED anymore boxes................. lol.
          Holidays over back to the Show and Tell
          Today a look at the Newer Mecool Pro L 3/32 with Voice Remote thanks to Gearbest
          Main Features:
          ● Combines durable 1.5GHz ARM Cortex - A53 CPU with Amlogic S912 chip
          ● Android 7.1 version, coupled with the rapid and stable configuration
          ● 4K / 3D video gives you high-quality video experience
          ● Dual-band WiFi gives you more smooth speed experience
          ● Bluetooth 4.1 connectivity. Easy pairing with most Bluetooth-enabled devices
          ● Support Miracast / DLNA / Airplay, share your video to your TV
          Looking Much the same as Previous except for a flash looking Voice BT remote.
          Lets get looking
          The Box simple as always
          A sticker on the back has the details
          What's in the Box
          The Remote
          Ports rear
          Ports Side
          Look Under
          Remove the Lid
          Out with the PCB and a look under
          Closer look Top Side
          Closer look other side
            Well this is Kinda Fun, Different, using the full ATV experience to set things up from start
            First we detect the BT Remote Hold - and OK as per screen instructions....and the remote is detected after a bit of a scan no hair pulling here.
            Setup up Google account Via Phone or tablet, why not
            Log into google via Tablet and find my device being the 912 pro L, few seconds done.
            Let's set up account and software (this is all done on tablet) ok do it what could go wrong.
            What wifi do you want the Pro L to use, picked one...all good.
            A few do you agree to this and that here and there (google stuff)
            Would you like to try the Android Remote on your table, sure gone this far not going to stop now.
            Loads shows a pairing code etc and done.
            Well that was a bit different and seems to work without any major hiccups or problems just read the screen.
            To the playstore now to do some updates load some testers and see what this has to offer in the way of performance.
            Haa Root explorer, Via Es file explorer Pro, being ATV no Upper or Lower Bars
            Aptoide ATV installed found most apps required for testing etc
            Good startup excellent, easy to follow and all seems to be working well with this Factory Rom from Mecool.
            Netflix 1080
            Click image for larger version  Name:	nf.png Views:	1 Size:	153.8 KB ID:	711310
              After all the set up its all pretty good
              Using Tablet with Android TV Remote, bit fun
              Blue Tooth remotes works well and Picks up speech easy more fun.
              As mentioned a Mixture Of Aptoide TV and Playstore to get the Apps you need no Big deal
              Wifi Working well, this is just a well good working unit
              Temps a bit high when Pushed as you will see small fan is your friend if you find it a bother.
              idle in the 60~70 no fan with fan down to 37c
              Lets have a look around and some test..
              Typical Android TV Rom
              App Draw
              System Info
              WiFi Looking Pretty Good
              DRM Info L1
              Ram and Storage Truth
              CPU-Z
              Bit warm:
              Testing show's it being pushed did not fail just hot, happens with these test
              Geekbench CPU... More Info >
              http://browser.geekbench.com/v4/cpu/7223779
              Geekbench Computer
              A1 SD Bench
              Youtube 4k
              Netflix 1080p as seen
              Has Root, Dev mode, and looking pretty good
              Finally a factory Rom from Mecool that has the the Goods.
              Hope others catch on or they are just not going to make it
              Normally not a fan of the ATV style rom this one has got my interest.
              Guess cause it works out of the box and does not need a lot further luv or attention. so far
              More fiddling and tinkering to come to see what else it can or can't do
              Remote works well with Voice commands piece of cake...
              Ask about the weather, decodes as you are speaking down bottom of screen
              Get an answer with Voice and Graphic. Fahrenheit at present to be sorted Just Ask for Centigrade and you get
              Temps seen below 60c a small fan was used Underneath, just an indication.
              Thanks Gearbest
              Also You can save $5 with Code: GBMCLB
                Nice initial review, thanks.
                If you don't see this during first boot do a Default Reset ...
                First Run Setup Instruction Screen
                Click image for larger version  Name:	WP_20180224_14_55_29_Pro.jpg Views:	1 Size:	71.8 KB ID:	710916
                Really liking this box, BT Voice Remote, and OEM ATV ROM.
                  Yep it's good, remote does works well,
                  About to post that image as i am going thru don't have to now...
                    Mi Box Remote vs Mecool BT Voice Remote
                    Click image for larger version  Name:	WP_20180226_13_27_30_Pro (3).jpg Views:	1 Size:	90.8 KB ID:	711385
                    Internals
                    Click image for larger version  Name:	AdobePhotoshopExpress_da668c8d498047fb9dfb0dcb4f45b748.jpg Views:	2 Size:	126.2 KB ID:	711386
                    Mecool is IR as well.
                    Needs IR to wake the box !
                      Thanks, Trebor, but you are a day late with the instructions on pairing the remote to this box......... Hahaha....... Took me awhile to find the correct "key" combinations to get it to pair. As PX discovered, Geekbuying test these boxes prior to shipping them (which is good), so we do not get the initial screen that tells us how to pair it.
                      • trebor
                        trebor commented
                        Editing a comment
                        Better late than never, less hair pulling = less bald people in the world
                      From what I heard it plays 4k at 30 frames no problem. 4k at 60 won't work.
                      but having voice plus Bluetooth and voice remote pretty sweet.
                        Is this box any better than M8S PRO DDR4, aside from the voice remote?
                        Is it worth to move from my current PRO 3/16 DDR4 to this one ?
                        Is this OEM ATV firmware compatible with M8S PRO?
                          Depends on how you use these but probably no to all 3 questions.
                          • trebor
                            trebor commented
                            Editing a comment
                            Has to be a little better,
                            You went and got one to go with all the others.
                          Ah, Trebor, yes but, I suffer from addiction. I have one Pro, and three of the L's, one I broke, and the third one, had to have that remote. Did I NEED them??? Heck NO, Why did I get them, could not help myself. Hahaha, of course, it doesn't help when you GOAD into purchasing them...
