Thanks for the suggestion, it's quite a step forward the solution, but we're still in deep waters here.
Mecool M8S PRO L Blue Tooth Voice Control 3/32GB Amlogic S912 A7.1 YT 4K Netflix HD Dual WiFi BT4.1 100Mbps
Originally posted by mymo View Post
So, I am in Europe and I have an Amazon Prime subscription. I followed the method suggested on the video: at first the application would install but wouldn't start since there was no prime icon or tile available. I thought it could be a region blocking issue, so I ran my VPN (pretending to be in New Jersey) and reinstalled the app, and I finally could find the icon in the app drawer. I started the application and I had to go through a double-verification procedure that required a pc to register my device. Upon its completion, I could finally browse through the movies and series, but here's the rub: it says the content is not available in my region and it does so both with my VPN enabled and disabled. This is obviously some sort of Android TV licensing issue because all the contents I checked ARE available and I had previously watched them on other devices.
Thanks for the suggestion, it's quite a step forward the solution, but we're still in deep waters here.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thanks for testing and verifying that it does't play the video.
Just checked my install that worked last month and now it doesn't !!! Says need to Update - But won't.
Tried uninstalling and reinstalling using PrimeLauncher and it just says have to Update again.
Looked at the Prime ATV app and last month it installed saying compatible on all my boxes, but now it is Incompatible with all my devices.
They seem to have updated some checks !!!!!!
Can you let me have the APK version number that you have that launches for you?
Cheers.
Just tried this apk
I got the link from this page
It installed OK, and seems to be the Shield version 4.1.121 (?) No KBD support - have to use on-screen
My membership has expired so I can't test the Video playback, maybe someone else wants to try ... playback may fail when verification starts ... ??
Cheers.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I don't know what else to think.
So, this one seems to be working a little better, in that it displays contents in my language and the app is localized in my language. It doesn't even warn me that the movie I want to play is not available for my country. But when trying to play anything, a dialogue pops up saying I have network issues and I should contact amazon technical support. I certainly have no network problems, everything streams ok, and I read this error message (which is also common on some Samsung tvs) is a sign of Dmr limitations.
Up to last month they let you watch in super low res 480, but even that has been stopped nowMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Amazon Prime Video.
I have tried all of the recent releases of Amazon Prime Video these are the current two 4.1.20 and 3.0.223.23841 both from Aptoide and both you can navigate the screen picks, play a trailer, but when
it comes to playing an actual video stream, it says "app has stopped" " contact xxxxx" I have use of an active account.
I looked at the video Clarkss12 recently put up, and the version he used is 3.11.44 which when I did a search is from EU and about 2016? I did not see it available via Aptiode, Maybe I missed it with my senior eyes. Neither my -W or -L had the TV Apps APK mentioned, I installed Aptoide.
It appears that Amazon is blocking use of these APK's due to some corporate decision. I have no idea how to solve or satisfy my family members that would like to
Use Prime on there MeCool devices. Other than get perhaps a RoKu-3 used for a few dollars and use it for Prime. They go for 10-20 on fleabay.
On another note: Both the MeCool M8S pro -W and -L with Voice have been running very smooth for the past two weeks without any freezes or glitches. Both have the Pi 30mm fans and rarely go above
41C while streaming 1080. Idles around 30/31C. Just as a note, I do not turn my unit off, they stay on all the time, I just switch the hdmi inputs on the tv's.
Other member of the family have the -W and -L without fans, but they get close to 80C on 1080 but so far no real issues, other than the Amazon Prime Video not available.
Thanks to all on the advise and help
Low Res only but seems to work - amazon-video_4.1.121.apk
https://disq.us/url?url=https%3A%2F%...Y&cuid=1370072
Found on this page in the comments.
Reports as Nvidea when signed in.
Keep your fingers crossed ...EDIT - No, it only worked first run, now failing
There are currently 2318 users online. 0 members and 2318 guests.
