Mecool M8S PRO L Blue Tooth Voice Control 3/32GB Amlogic S912 A7.1 YT 4K Netflix HD Dual WiFi BT4.1 100Mbps
    Originally posted by mymo View Post
    I found a way to watch Amazon prime contents on this device.
    It can't be done through the Amazon app as we all know now, if nothing has changed since the last time I tried, but it can be done through Kodi. All you need is
    Kodi 18 Leila (I used the latest Nightly)
    Amazon addon by Sandmann79 (it can be installed through this repo https://github.com/Sandmann79/xbmc/r...gins-1.0.2.zip)
    Once finished installing, open the Amazon video or Amazon Vod addon (depending on the country you live in), and configure it by entering your email, password and the secret code that will be sent to your email account. Then it will automatically install some add-ons upon which it depends and ask you to enable Inputstream. Don't forget to select "playback with Input stream" during the configuration.
    There can be still issues with the subtitles, otherwise the add-on works like a charm... I tried HD stream so far, I haven't tried full HD yet.
    EDIT: Well, not like a charm, but it works
    This isn't working for me using Kodi v17.6. It has no sound and just garble picture and is using 720p
      Does say Kodi 18
        Does say Kodi 18
        Yes' Sir, I know you said v18. but I had to try, I still have way to many issues with v18 yet and certain addons not working (my wife might disown me with her stuff working the way she likes it. lol).
          Yes, a problem that !
            with this mecool m8s por L is it possible to access a hard drive that is attached to my router.. an archer c7 i dont know if android tv has samba enabled... sorry if its a dumb question
            also if i need to attach my western digital 500gb drive to the usb port does it need an external powered hub and can i copy files to this hard drive from my PC
            \thanks in advance
              This trick has worked on my LB box as well. I have used Kodi's latest alpha build 2 (18 Leia alpha 2) with Amazon VOD addon from sandman79 repo.
              Amazon videos are played at 720p resolution by default (better than nothing).
              Thanks again for sharing the trick, mate!
                I am on latest Mecool M8S Pro L LB version with stock TV Rom.
                I have weird problem in Youtube for Android App (default one that comes with stock rom). After playing the video for few seconds (say 20 sec), the app hangs with black screen no audio/video. I have updated the app to the latest one but still the problem persists. If I use, Youtube addon via kodi then there are no such issues.
                I like the use of voice remote to search for content in default Youtube for Android TV app, hence would love to use it over Kodi's where i have to type everything.
                Any help on this would be much appreciated!
                Cheers!
                  You're welcome. Actually videostream can go up to full hd (you can also choose the bitrate). You just need to select the manual stream feature in the settings menu. Only stereo audio will be available though.
                  Inviato dal mio Redmi Note 4 utilizzando Tapatalk
                    \thanks in advance
                    I can't tell about the hdd attached to the router, but I'm sure you'll need a usb hub if you want to attach it to the box.
                    I don't think Android tv has a bulit in Smb server (take my words with a pinch of salt) but you can sideload Samba filesharing for Android.
                    I'm sorry to disappoint you, but once you hook up the hdd to the box you won't be able to write or delete data on it with a file manager, because Android tv doesn't allow write access to external drives. Therefore, every app can only access to the folder it creates on the hdd.
                    To avoid that, you can install a custom rom.
                      Cheers!
                      I have solved that uninstalling the latest version of the YouTube App (2.03.04)... and disabling automatic updates
                        did anybody try hopwatch apk on this mecool m8s pro l ATV? and the apk works or not on it, and i tried to install, but can not purchase, since that apk is forbidden in my country, and my payment failed( usd1 for that apk). many said this apk is very good. i need to check and regret can not ....can anybody try it? and let me knwo. thanks.
                          I am having issues with youtube. Even tried uninstalling it but everytime I try my system reboots and the darn thing is still there.
                          Wanted to uninstall and install the previous version. Even selecting uninstall updates forces a system reboot.
                            Very good!!!
                            Do you have a link for a tutorial step by step to install Kodi, libreleec without risk i kill the box?
                              Originally posted by Robbynaish View Post
                              Very good!!!
                              It's also working on kodi nightly apk, no need to install librelec, you can do it on android.
                                Hi Trebor
                                Can you get the original firmware for this box "M8S PRO L-userdebug 7.1.1 NHG47L 20180205.111652.V0928 zip or img"?
                                Thank you
