Mecool M8S PRO L Blue Tooth Voice Control 3/32GB Amlogic S912 A7.1 YT 4K Netflix HD Dual WiFi BT4.1 100Mbps
Hi All. I got my Mecool M8S PRO L box about 3 weeks ago. Everything was working fine up to now. For some reason Netflix has stopped working. I get error code NW-6-406. I have uninstalled Netflix reinstalled Netflix, even reset the box, still get the same error. Spoke to Netflix support and they don't know either why its not working. Any suggestions? Everything else works 100% connected to the internet. Vader streams, youtube etc all works perfectly.
Originally posted by joefriday View PostHi All. I got my Mecool M8S PRO L box about 3 weeks ago. Everything was working fine up to now. For some reason Netflix has stopped working. I get error code NW-6-406. I have uninstalled Netflix reinstalled Netflix, even reset the box, still get the same error. Spoke to Netflix support and they don't know either why its not working. Any suggestions? Everything else works 100% connected to the internet. Vader streams, youtube etc all works perfectly.
Originally posted by XXBrain View Post@chnaski Amazon Prima was is not working. There is only an unstable workaround with kodi for 720p. Looks like Netflix is still working with a special tablet version, that is linked in the mentioned thread above.
As you can imagine i'm pissed off.
Originally posted by XXBrain@chnaski Amazon Prima was is not working. There is only an unstable workaround with kodi for 720p. Looks like Netflix is still working with a special tablet version, that is linked in the mentioned thread above.
Inviato dal mio Redmi Note 4X utilizzando Tapatalk
Originally posted by chinaski
Yes, I know .Unfortunately I didn't double check before buying Amazon prime compatibility before buying. But Netflix ( 1080p) out of the box was the main reason for buying the m8s pro l. And now, 24 hours after receiving the box, isn't working anymore.
Originally posted by antcasq View PostThe NW-6-404 fix is in page 4 of the thread "Netflix in HD is being killed in some of the Chinese boxes".
Download the ZIP file (Burn-key-tool.zip) provided by Videostrong, unzip it and install the APK. It will update the widevice license that is causing the issue.
Trying to use bluetooth to connect to my Sony SRS-SB2 bluetooth speaker.
Can't get the Mecool to see SRS-SB2.
Can see remote control and my Pocophone.
I have rebooted Mecool, switched WiFi off and on, set my SRS-SB2 to pairing mode, all the usual...
Any ideas on why and how I can get Mecool to see SRS-SB2 so I can pair it.
There are currently 2163 users online. 2 members and 2161 guests.
