Also is there a way to do a TWRP backup as a zip and somehow create an .img file out of that which can then be flashed with stock recovery?
linux-amlogic-toolkit - unpack and repack AMLogic images using Linux (works with Android 7 !)
It is Android 7.1, you can lookup for yourself if you want it's the GT1 TVStock ROM.
You can create an IMG file out of a ZIP backup but that will require special work for each partition, and you will certainly have permissions problems for the system partition. I would not recommend doing that, not worth the hassle. You can use dd to directly extract the PARTITION files from the device, which you can then put in my toolkit.
Originally posted by natinusala View PostIt is Android 7.1, you can lookup for yourself if you want it's the GT1 TVStock ROM.
You can create an IMG file out of a ZIP backup but that will require special work for each partition, and you will certainly have permissions problems for the system partition. I would not recommend doing that, not worth the hassle. You can use dd to directly extract the PARTITION files from the device, which you can then put in my toolkit.Perhaps if you have time skype chat would be easier? whichever you prefer.
I don't know if I'm allowed to use XDA links here but I'll do it anyway : https://forum.xda-developers.com/sho....php?t=2450045
This post explains everything needed
Originally posted by natinusala View PostI don't know if I'm allowed to use XDA links here but I'll do it anyway : https://forum.xda-developers.com/sho....php?t=2450045
Originally posted by natinusala View PostI didn't say anything above won't work, but it supports at least 2.2Gb images.
So I try to run parted /dev/block/mmcblk0 print and it gives me an error that uncorecognised disk label. I then try to mount mmcblk0p13 which is "data" and it tells me no such file or directory. It also seems that there is no /dev/block/partitions/by-name there is only /dev/block/partitions/by-num. So something here is definitely wrong. If I try to do dd if=/dev/block/data of=/sdcard/data.img and I get one huge data.img file. Is this data.img in fact my overall data folder?
I have attached a file, you can see clearly that mmcblk0p13 exists but give no file or directory. What is the issue?Last edited by korgix300; 31 March 2018, 14:55.
Natinusala, there has been a long-standing error in abootimg (and unmkbootimg, although that doesn't affect your toolkit). Would you be willing to fix it in your copy of abootimg? Here's a diff of the bad and fixed versions of abootimg:
721c721
< printf (" second stage size = %u bytes (%.2f MB)\n", ramdisk_size, (double)ramdisk_size/0x100000);
> printf (" second stage size = %u bytes (%.2f MB)\n", second_size, (double)second_size/0x100000);
846c846
< unsigned n = (rsize + ksize + psize - 1) / psize;
> unsigned n = (rsize + psize - 1)/psize + (ksize + psize - 1)/psize;
This problem shouldn't affect Nougat and Oreo images but it definitely affected previous versions of Android.
Thanks for making your toolkit available to everyone!
But regardless of parted I am confused why M8SPro L doesn't have /dev/block/platform/d0074000.emmc/by-name ?
Every single posting on freaktab I investigated and all the people that had only by-num vs by-name never got a response how to do "dd". Do you know how to do "dd" in cases like these?
I did dd if=/dev/block/dataof=/sdcard/data.img and got a 9.19GB file even though my overall internal storage ihas been only 2.12 used, how did it create a 9.19GB file?. What's happening here?
I am basically looking to backup "data". "data" is showing mmcblkop13 if I execute cat /proc/partitions
If you know how to resolve this you are the master.
The starting address of the second bootloader in the boot partition is calculated wrong in ~20% of the cases. This usually doesn't cause a problem since the second bootloader isn't used very often. But since Amlogic stored their DTBs in the second bootloader for Marshmallow and earlier versions of Android, this will affect them.
I tried out your code and it works pretty well. It's nice being able to save an unpacked image and work on it slowly over time rather than doing it all at once when using the Customization tool.
I noticed your copy of the logo_img_packer is a 64-bit binary whereas all of the other executables are 32-bit so that stops 32-bit Linux users from using your toolkit. I've attached the 32-bit version.Attached Files
There are currently 1966 users online. 1 members and 1965 guests.
