linux-amlogic-toolkit - unpack and repack AMLogic images using Linux (works with Android 7 !)
Found another residing issue due to project treble in 8.1 R4, the vendor partition will not boot if you dont append both plat_file_contexts and non_plat_file_contexts(found in the recovery ramdisk) and using a special version of make_ext4fs to reference /system as found by Carmine, im currently compiling a windows version but its not looking good as im struggling to get Cmake V3.10> successfully compiled let alone libz issues
Originally posted by natinusala View PostPut your system.img in the correct folder (output/image I think ?), remove the repack line from the script and run the flashing tool
Originally posted by natinusala View PostYou can shrink the system image by doing
./bin/unmount
e2fsck output/image/system.img
resize2fr -M output/image/system.img
./bin/remount
However this will leave you with 0 bytes free on your image partition, preventing you from adding any additional file. I don't think this is what you want.
Please tell me how to fix logo errors on old linux-amlogic-toolkit version (http://ltpvietnam.com/linux-amlogic-toolkit-master.zip)
I used to not see error before, After I reinstalled the windows operating system, it failed. (I use ubuntu on a virtual machine)
Originally posted by lethanh View PostPlease tell me how to fix logo errors on old linux-amlogic-toolkit version (http://ltpvietnam.com/linux-amlogic-toolkit-master.zip)
Originally posted by lethanh View PostIf you have it please give me, I used to use that version very well. but i have lost the old version. new version when repack I don't see any changes
There are currently 1873 users online. 2 members and 1871 guests.
