Customization Tool works for Android <= 6. For Android 7+ you'll need this tool, or any other "Linux" method (mostly by hand).
linux-amlogic-toolkit - unpack and repack AMLogic images using Linux (works with Android 7 !)
Originally posted by natinusala View PostWell this tool is intended to be used on Linux. You're not forced to use Ubuntu or Debian, but then you'll have to install the dependencies yourself.
Customization Tool works for Android <= 6. For Android 7+ you'll need this tool, or any other "Linux" method (mostly by hand).- https://github.com/khadas/utils for the aml_image_v2_packer and logo_img_packer binaries
- https://github.com/anestisb/android-simg2img for the simg2img tool
- https://github.com/ggrandou/abootimg for the abootimg tool
Or- zlib1g-dev for simg2img and img2simg
- libblkid-dev for abootimg (unpacking and repacking boot image)
Originally posted by natinusala View PostYou have to install what is stated as "Dependencies" in the README, so it will be zlib1g-dev and libblkid-dev (or their equivalent in your distribution / package manager)
One stupid question ... which .img do you use for editing ? I opened the whole Nexus img from Magadenz and I got a few directories (attachment). How do I get to the boot logo and bootanimation to actually edit the files/pictures?
thanksLast edited by korgix300; 29 March 2018, 20:03.
You have the list of everything generated and their location in the output directory in the README of the repository. To change the boot _animation_ you'll want to change the output/system/media/bootanimation.zip file (IIRC). To change the boot _logo_ you'll have to edit the output/logo/bootup file. Be careful as the bootup file format may change depending on your device (BMP pixel depth, GZ compression...).
Originally posted by natinusala View PostYou have the list of everything generated and their location in the output directory in the README of the repository. To change the boot _animation_ you'll want to change the output/system/media/bootanimation.zip file (IIRC). To change the boot _logo_ you'll have to edit the output/logo/bootup file. Be careful as the bootup file format may change depending on your device (BMP pixel depth, GZ compression...).
Btw in Magadenz's ROM the output/logo/ folder is empty so not sure where that logo is.
ThanksLast edited by korgix300; 30 March 2018, 15:43.
Originally posted by natinusala View PostYou can flash it using a recent version of TWRP or using dd on a terminal on the device or ADB shell (simpler).
Concerning Magendaz's ROM, I use it personally and I was able to unpack, edit and repack the logo partition without any trouble.
When you unpack and locate output.logo folder you see the boot image, you then change it and repack and then you flash the whole img/whole ROM? My question was once you do change the boot image can you just flash that boot image in TWRP or do you have to flash the whole ROM.
Also when you unpacked Magadenz's image do you get anything in the output/logo folder because I don't see any file it says 0 files?Last edited by korgix300; 30 March 2018, 18:47.
Originally posted by natinusala View PostYou can do whatever you want, you can flash only the logo partition (logo.PARTITION) of the whole ROM (be careful at the latter will probably wipe all of your data).
And yes, when unpacking Magendaz's image I have files in output/logo
How do you flash logo.PARTITION in TWRP ?
Originally posted by natinusala View PostCan you give me the full logs of the unpack script ?
You'll have better results flashing it with dd using a terminal on your device (assuming it's rooted). First, find the block file for the logo (for me it's /dev/block/logo) and $ dd if=/path/to/logo.PARTITION of=/dev/block/logo
I have attached the log if this is what you were looking for.
Note: I have used customization tool to open the image then replace the boot logo with mine and pack. Then I ran your unpack in debian and got logo.PARTITION which I am going to dd. But wondering if I can use your tools instead of hacking with customization tool and yours.
Once I do a TWRP backup do you know if there is a way to make it into an img file so that I can flash it with stock recovery?
ThanksLast edited by korgix300; 30 March 2018, 19:26.
Originally posted by natinusala View PostIt looks like the logo_img_packer tool cannot unpack the logo partition for your device or for this particular image, I'm afraid there is not a lot I can do to help you. Did you do something weird on it ?
I have also included log as I have deleted output folder and re-started with your instructions to install the tools. Seems something is missing...Last edited by korgix300; 30 March 2018, 19:55.
There are currently 3742 users online. 1 members and 3741 guests.
