korgix300 if you just want to backup the data partition, why don't you just extract the zipped backup from TWRP ? Unless you want to restore this on another device without TWRP ? AMLogic images (and Android in general I guess) don't support data partitions pre-loading (or I didn't find how to) so you will not be able to put your data.img in the packed ROM anyway
linux-amlogic-toolkit - unpack and repack AMLogic images using Linux (works with Android 7 !)
01520717 I fixed everything, thank you for reporting this !
Originally posted by natinusala View Post01520717 I fixed everything, thank you for reporting this !
So this should work right?
My idea is to do this and create a normal IMG so that I could flash with stock recovery not TWRP
Originally posted by natinusala View PostYou can't add the data partition to the original image using my toolkit. I don't even know if Android or AMLogic supports it.
How about if I just want to take an .img of my whole box as it is, is that possible and then just flash to another same box with stock recovery?
Originally posted by james739 View PostThank you great work with this toolkit. I'm using sudo nautilus in ubuntu to modify the files. After repacking, I'm stuck at boot loop on my box. Any idea what's causing this or how to find out?
Then use midnight commander.
Using Nautilus can be strange cause it changes some file permission maybe.
Neomode
ricky divjakovski please let me know when you find a fix, I might need it for my toolkit too, thanks
Originally posted by natinusala View Postricky divjakovski please let me know when you find a fix, I might need it for my toolkit too, thanks
However PM me or email me, my toolset is almost fully complete, minor tweaking but its proving very effective
There are currently 2448 users online. 1 members and 2447 guests.
