Help me please erro [0x30405004] USB burning tool
S / N AX12GSLF50114 32GB. The PCB version is GT-F Ver2.0I can not make this box work again, I tried the conventional reset and error by the sd card: "cache error". at this point I can not do the same for usb burning 2.0.9 is 2.0.5 due to this error [0x30405004] UBOOT / Partition System / Check the patience / and stops at 98%. All this after a freeze when watching a video on Youtube. report erro USB birning tool 2018.02.21-18.pdfYou may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosTags: None
M8, if you search the from and even on Google, you will find that updating this box is the first mistake people do as you have more than 50% chance of getting stuck with a brick on your hands. If the update is with official firmware than the chances are even bigger. DO NOT UPDATE WITH OFFICIAL FIRMWARES
@WilliamD22
did you resolve your problem?
I have the same model and the same board and the box is totally bricked, just have blue light.
Tried everything I can find but no luck.
Usb burning tool can recognize the box but have error on 2%.
Originally posted by Nebojsa View PostYes, I already tried that, but no luck.
Nothing happened, black screen like always.
Tried different roms, all the same.
One time I waited half hour, just to be sure, but nothing.
Originally posted by Nebojsa View PostI done everything like you said about 20 times, no luck.
Like I said, I tried to leave it for half an hour, but nothing happened, just black screen.
Originally posted by Nebojsa View Post4 different PC's
different os, Xp, 7, 8.1, 10,
always port on the back
5 or 6 different cables..
My SN is also AX12.
[0x10105002]romcode/initialize ddr/read initialize status/USB control setup error
this is the error on 2%
[0x10303004]romcode/switch status/identify/error result
this is the error on 4%
Tried lot of roms with N0 but no luck, everytime those errors.
Have very good cable, tick and short, 50cm.
I can't remember what version was before.
I tried every possible combination, check erase bootloader, uncheck erase bootloader, normal erase, force erase all, with power supply, without power supply...
I do not have the problem with recognizing devise, USB Burning tool always recognize it, problem is when flashing start.
There are currently 2498 users online. 0 members and 2498 guests.
