Help me please erro [0x30405004] USB burning tool
Done everything, here is boot log, can't see any errors, that's a good thing:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY:0 ;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 139700
BL2 Built : 11:58:42, May 27 2017.
gxl gc3c9a84 - xiaobo.gu@droid05
set vdd cpu_a to 1120 mv
set vdd cpu_b to 1050 mv
set vddee to 1000 mv
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0+1 @ 816MHz
Rank0: 2048MB(auto)-2T-18
Rank1: 1024MB(auto)-2T-18
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x00018400
Load bl33 from SD, src: 0x0003c200, des: 0x01000000, size: 0x00066200
▒▒GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY :0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 139665
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
TE: 139706
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
I'm back.
Here's the log, box isn't booting...
TE: 142347
BL2 Built : 13:18:48, Dec 21 2016.
gxl g4fc4d4e - xiaobo.gu@droid05
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DDR4 chl: Rank0+1 @ 636MHz
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
Load bl31 from SD, src: 0x00020200, des: 0x10100000, size: 0x00015400
Load bl33 from SD, src: 0x00038200, des: 0x01000000, size: 0x000a9a00
DFC318C:80;POC:3;RCY:0;EMMC:0;READ:800;SD:0;READ:0 ;0.0;CHK:0;
TE: 142389
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
▒xceGXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;R CY:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 142380
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
▒xcGXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RC Y:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 142372
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
TE: 142378
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
dGXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:3;RCY: 0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 142439
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
That is the log, then everything is repeating over and over...
Do not have another micro sd card, can that be a problem? I can tell the card is working normally as i can see...
I tried with another power supply and it's the same, tried this power supply to another box (5V 2A) and box is working normally, so the power is ok.
Some progress!
The log was changed when I plug, beside power supply, also the usb cable!
So, now is connected power, usb male to male to port next to the micro usb, UART and HDMI with tv.
Box still won't boot.
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:2;RCY:0 ;USB:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 147967
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
NOTICE: BL3-1: v1.0(debug):2e39a99
NOTICE: BL3-1: Built : 16:36:21, Sep 20 2016
aml log : bl31 normal boot !
[Image: gxl_v1.1.3154-065f772 2016-09-29 14:08:54 yan.wang@droid05]
OPS=0x82
8b a8 52 a4 2f 34 df e4 3 3c 95 50 [0.562517 Inits done]
secure task start!
high task start!
low task start!
INFO: BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR: Error initializing runtime service opteed_fast
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x1000000
INFO: BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-gf3cbd70 (Feb 24 2017 - 22:51:16)
DRAM: 3 GiB
Relocation Offset is: b6ec9000
Ok, hdmi cable is unplugded, but the log is the same:
TE: 147899
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
Rank0: 2048MB-2T-18
Rank1: 1024MB-2T-18
DataBus test pass!
AddrBus test pass!
New fip structure!
OPS=0x82
8b a8 52 a4 2f 34 df e4 3 3c 95 50 [0.562439 Inits done]
secure task start!
high task start!
low task start!
DRAM: 3 GiB
There are currently 1383 users online. 1 members and 1382 guests.
