Help me please erro [0x30405004] USB burning tool
He he, great!
bumerc can you please re-upload u-boot, it's on my other pc at home and I'm not, like to tried it now.
OK, I removed shield, it's look like this:
https://s20.postimg.cc/so2zdhimh/IMAG3054.jpg
https://s20.postimg.cc/j3jcqm109/IMAG3055.jpg
Thanks.
Tried with this u-boot but all the same:
GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:2;RCY:0 ;USB:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
no sdio debug board detected
TE: 147058
BL2 Built : 11:58:42, May 27 2017.
gxl gc3c9a84 - xiaobo.gu@droid05
set vdd cpu_a to 1120 mv
set vdd cpu_b to 1050 mv
set vddee to 1000 mv
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0+1 @ 816MHz
Rank0: 2048MB(auto)-2T-18
Rank1: 1024MB(auto)-2T-18
DataBus test pass!
AddrBus test pass!
Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x00004000
New fip structure!
Load bl30 from SD, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from SD, src: 0x00020200, des: 0x05100000, size: 0x00018400
Load bl33 from SD, src: 0x0003c200, des: 0x01000000, size: 0x00066200
▒GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:2;RCY: 0;USB:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 147075
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
Y▒▒GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:80;POC:2;RC Y:0;USB:0;EMMC:0;READ:800;SD:0;READ:0;0.0;CHK:0;
TE: 147173
Board ID = 6
CPU clk: 1200MHz
DQS-corr enabled
DataBus test pass!
AddrBus test pass!
New fip structure!
Adapter is ok, I tried 3-4 different adapters, all the same. This adapter works perfectly fine on my second, working box.
https://s20.postimg.cc/rgy8cphjd/IMAG3056.jpg
https://s20.postimg.cc/agfc41c7t/IMAG3057.jpg
Like I said, check each power supply segment. A blown fuse resistor, or transistor switch for controlling sleep and wake will do it. Not familiar with your board, but transistor is located next to the power connector on the reverse side near the corner.
you could have a blown 3.3v stage as well... not necessarily the power output, but a resistor or transistor to control it. Each stage should have one to either enable when power is applied, or control ed by CPU for sleep.
try connecting USB power as well as power adapter. Should help if hardware is an issue with passing 5v to the step down stages for voltages.
thus making uart active, without adding 3.3v from the adapter.
Ok, thanks.
When I said that adapter works on my other box, I meant power adapter. I power my working box with power adapter from non-working, if box works normally then I assumed power adapter is ok.
X92-2GB Thanks, will try first all software possibilities, if nothing helps then will move to hardware.
If one does not have 3.3v active in their circuit, no communication is going on, let alone the box is not giving power to the uart and/or other devices that need it.
There are currently 2090 users online. 0 members and 2090 guests.
